Will this work?
Old Nov 5, 2001 | 08:11 PM
SpeedracerS4's Avatar
Default Will this work?
Can I swap out a US ITR LSD and put it in a GSR Trannie?
Old Nov 5, 2001 | 08:44 PM
OneThirtyEight's Avatar
Default Re: Will this work? (SpeedracerS4)
I belive so. I think most B series trannys are interchangable. not 100% sure, but im pretty sure you can.
[Modified by 97blackteg, 12:45 AM 11/6/2001]
Old Nov 6, 2001 | 09:29 AM
eternal21's Avatar
Default Yes..
...you can. All B-series hydros are interchangeable.
Old Nov 6, 2001 | 10:40 AM
Katman's Avatar
yep..
Hydro GSR/LS/Si Coupe/CTR/ITR differentials & LSD's are all interchangeable.
however...
hydro 92-95 Y21/S21 trannies are not interchangeable...somewhat.
Why? because the diameter of the ring is smaller than that of GSR/LS/Si Coupe/CTR/ITR's ring.
you should be ok if you have a GSR tranny though - and using an ITR LSD.
Hemix
Transmission & Drivetrain
14
Apr 30, 2010 08:07 PM
HondaTeKnology
Mar 20, 2008 11:40 AM
Micro
Nov 10, 2003 03:18 PM
Screaming Vtec
Apr 5, 2003 03:32 PM
