anyybody encounter stripped threads in the block
Old May 11, 2004 | 09:19 PM
desert eagle's Avatar
Default anyybody encounter stripped threads in the block
my driver side mount threads in the block are stripped. i can not get a torque. any suggestion before i drop the engine?
Old May 11, 2004 | 10:05 PM
triggerX's Avatar
Default Re: anyybody encounter stripped threads in the block (B20vtec81)
Your going to have to drill it and rethread the hole. If you skip this step then the engine mount may not be able to withstand the engine vibrations.
Old May 11, 2004 | 10:08 PM
Super_Eg6's Avatar
use helicoil to retap the treads...you need to fix the problem before the engine gets dropped in
Old May 12, 2004 | 06:11 AM
DaX's Avatar
DaX
Loved
Community Favorite
Helicoil
Old May 12, 2004 | 09:12 AM
Default Re: (Super_Eg6)
thanks fellas. the engine is in the car right now. looks like im gonna have to drop it huh?
Old May 12, 2004 | 02:49 PM
Ekasey's Avatar
Default Re: (B20vtec81)
depending on how bad the threads are stripped i would try running the proper size tap through the whole first before you drill and heli coil. The threads may be salvageable, but if that doesnt work helicoil gets my .
C_Rock77
18
Dec 2, 2018 12:47 PM
biggoofy
Feb 13, 2009 06:28 PM
TurboEG6
Nov 9, 2003 09:58 PM
PSU-TEG
Apr 30, 2003 08:55 AM
