Do V-afc's really help performanc?
Old May 11, 2004 | 09:11 PM
JsNA99si's Avatar
Default Do V-afc's really help performanc?
I have heard they are just colorful tachs and then i have heard they can make power, im putting one on soon unless im persuaded to do otherwise. Just trying to find some people who have good or bad things to say about them, mine will not be dyno tuned for a while untill i have money. So let me know what you guys think about them.
Old May 11, 2004 | 09:25 PM
WrongWD's Avatar
"Tim's Soap Box on Piggback AFCs
Original banter by: Tim "The Stick"
Ok, this topic has been beaten like a dead horse, but I keep seeing the SAME question time and again. So, lets answer the eternal question:
"Where can I put my AFC?"
In a trash can. And that's the final answer folks. Here's why for archival posterity:
An air fuel controller adjusts fuel control, and in some cases VTEC activation. This is GREAT for a DSM (like a 4G63 eclipse/tallon etc...) because that engine uses a MASS AIR FLOW SENSOR. Honda's use MAP sensors (manifold absolute pressure, or intake air pressure sensor). What's the difference between the 2 and why will it work for one and not the other??? Simple.
-A Mass Air Flow system adds fuel based on "How much air did I just suck up". MASS AIR IS A REAL VALUE. Real values have a basis, and no further calculation is needed. "X air needs X fuel." Adjusting any values PAST that point in the ECU's equation is OK!!!!! If you add fuel to that mixture (by increasing the injector duration), then the ECU will acknowledge that input and add fuel.
-A MAP sensor style system only see's what the manifold pressure (and other data) is, and then has to CALCULATE in order to figure out "How much air did I just suck up?" This number is NOT a REAL VALUE, but a derived value, and therefore is a variable. "X manifold pressure-times X throttle position-times X RPM-times X intake air temperature-times......." ".....equals how much air I FIGURED OUT that I sucked up." See the difference?? The ECU NEEDS this data in order to come up with a derived number for "X fuel."
So here's ALL the reasons why NOT to mount up your AFC:
1: ALL Correct Sensor Data is NEEDED.
A Honda needs all it's sensor data, and needs to recieve it CORRECTLY to determine how much air it's getting. It auto adjusts for fuel consumption based on these sensor values. If you're running boost, then you need to TELL THE ECU it's getting it. Unfortuneately, a Honda ECU in stock form doesn't have the programming for any manifold pressure ABOVE normal barometric pressure. So, what happens when a Stock ECU see's boost at the MAP sensor??? The ECU doesn't have enough data to calculate the fuel table, so..... "Check Engine." "Please help me, I'm an ECU and I'm dumb, what does 7 psi mean?? I don't have that number in my tables, so I can't calculate. Wait a minute....if I don't have that number, then the MAP sensor must be broken, because if I don't have the number, then it doesn't exist. Please replace the MAP sensor." An AFC won't cure that. ONLY A NEW ROM CHIP WITH BOOST TABLES WILL CURE THAT.
2: The ECU "auto adjusts" itself.
Lets say you want to tune in 10% more fuel with your AFC. Fine, tell your AFC to add 10% more fuel. No problem right?? Wrong. What happens to the O2 sensor when it's got 10% more fuel?? It tells the ECU that it's running 10% rich. So, the ECU "auto adjusts", and takes 10% out of the mixture. You've added 10% with the AFC, and the ECU has taken 10% back out to get back to stoich. What's the net increase in fuel?? That's right, 0%. NOW...... Lets add fuel untill the ECU can NO LONGER adjust (or, you've added so much additional fuel that the ECU doesn't know what's happening, and can't compensate that far). Simple. You run rich. "Hi, I'm the check engine light again. There must be something wrong with my O2 sensor because I've backed the fuel off as far as I can go, and it keeps telling me that I'm still too rich. Please change the O2 sensor for me, because that must be what's wrong with me. Thank you."
3: VTEC engagement point calibration.
VTEC is a combination of 3 different things. 1: The changeover of the cam lobes. 2: The changeover of the fuel MAP. 3: The changeover of the Timing MAP. If these 3 things don't happen all at the same time, what happens?? Simple again, you have a "hole" in the fuel and timing MAPS. If VTEC engages at 3000 RPMS, and the fuel and timing table follow the ECU's instructions and changeover at 5200, then have you added any more fuel and or timing from 3000 untill 5200?? No. Therefore, what did you gain?? Nothing. So what, the cam changed over, but you didn't add any fuel to it, or change the timing curve. You got more air, but the ECU didn't know that it was going to get it! So it didn't DO ANYTHING ABOUT IT. Yes, adding more air makes it FEEL like you're making more power sooner, but all you're REALY doing is running lean for a few seconds.
4: An AFC can't tell the ECU what kind/size/style injector you're running.
The ECU is programmed for one particlar injector size and style. The one that CAME in your car from the factory. If you change the injectors to a larger size, the ECU MUST be reprogrammed in order to realize this, and take awayor add some injector duration. If .013 seconds is the time an injector needs to be open to add fuel at 4600 rpm's at wide open throttle with a 240 cc injector, then how much MORE fuel is added with a 440 cc injector held open for the same amount of time?? Correct. Nearly double. That means you've added 2 times MORE fuel than the ECU thought it added. "Hi, it's me again, Check Engine. Yeah.... Ummm, What the ****."
NOW. Let's look at the options to an AFC controller.
-An aftermarket ECU (Spoon, Mugen)
-A modified ECU with a programmable ROM, AND additional memory in piggyback form (Hondata)
-A plug and play fully programable ECU (AEM)
-A totaly programable blank slate ECU (Halltech)
ANY of these will allow for WHATEVER you decided to program for. Bigger injectors. Boost. Different Cams. Higher shift points. Higher rev limits. Anything you want. You can have ONE of these systems do it for you, and do it correctly.
Some are expensive, some are inexpensive (AEM costs about $1,600.00, and Hondata starts at $295.00). But the bottom line remains, YOU HAVE TO HAVE ONE IF YOU EVER WANT TO ADD MORE FUEL OR TIMING CORRECTLY to a Honda. For what it would cost to get an AFC controller, an MSD system with boost retard, a new set of injectors, etc... "YOU CAN AFFORD TO GET THE CORRECT SYSTEM THAT WILL WORK FOR A HONDA."
So, use this knowledge well, for it will be the LAST time the question is CORRECTY answered for you. Please refer to this article and search sway to your hearts content for it. Many will disagree with these statements, but to those who DO disagree....... Buy an aftermarket ECU and tell me what you think. You'll agree, and admit you were wrong all these years.
Stick"
Old May 11, 2004 | 09:32 PM
JsNA99si's Avatar
Default Re: (WrongWD)
Damn that really explains why it wouldnt work. But still leaves me wondering how people have gotten dyno proven gains from it, if it is so wurthless.
Old May 12, 2004 | 07:04 PM
jweller's Avatar
Default Re: (baby99si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baby99si &raquo;</TD></TR><TR><TD CLASS="quote">But still leaves me wondering how people have gotten dyno proven gains from it, if it is so wurthless.</TD></TR></TABLE>
ummm yeah. I'll agree that an afc isn't the best or correct way to do it, but people dyno gains from them all the time. so what gives?
Old May 12, 2004 | 07:10 PM
H25's Avatar
H25
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baby99si &raquo;</TD></TR><TR><TD CLASS="quote">Damn that really explains why it wouldnt work. But still leaves me wondering how people have gotten dyno proven gains from it, if it is so wurthless.</TD></TR></TABLE>
LOL that is so true.. I wonder why every car that we install a vafc and a chipped ecu on gains min 8-11whp... it must be the magic whp fairy... thats gotta be it..
Old May 12, 2004 | 07:19 PM
Grip's Avatar
Default Re: (MHRacing-310)
ive seen a car go from 208 to 212whp with a simple adjustment of a v-afc..and get this..it was a honda
who the hell is "stick" anyways?..probally a dsm lover
Old May 12, 2004 | 07:22 PM
Revhard92si's Avatar
Personally I don't think the V-AFC is trash. You can gain horspower with it. If you're running lean, you can use the afc to adjust the fuel. You can set the vtec engagement at what ever rpm your cam requires for best power result. For the mild honda enthusiast the V-AFC is difinitely a plus.
Old May 12, 2004 | 07:25 PM
JsNA99si's Avatar
Default Re: (Revhard92si)
Might as well throw this question in here, what is the best v-tec engagment for Type R cams? 5700?
Old May 12, 2004 | 07:30 PM
Padawan's Avatar
Darth ModerVader
Basically because very little in that post is actually accurate information...
Old May 12, 2004 | 07:46 PM
JsNA99si's Avatar
Default Re: (Padawan)
I figured, that is why i just kind blew it off.
Old May 12, 2004 | 07:48 PM
SkRiBLaH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baby99si &raquo;</TD></TR><TR><TD CLASS="quote">Might as well throw this question in here, what is the best v-tec engagment for Type R cams? 5700?</TD></TR></TABLE>
5300
Old May 12, 2004 | 07:57 PM
Padawan's Avatar
Darth ModerVader
It honestly depends upon the particular setup. I know of a couple of mildly modified ITR's tuned with Hondata that utilized VTEC points in the 3000 RPM range. There really isn't one "ideal" point, but 5700 (basically stock ITR point) is probably a decent rough figure if your setup closely approximates an ITR motor.
Old May 12, 2004 | 09:16 PM
JsNA99si's Avatar
Hmm, if i were to give my setup could you guys give me a better guess to set it at till it gets dyno tuned?
Old May 12, 2004 | 10:08 PM
VAAJ's Avatar
Default Re: (Grip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grip &raquo;</TD></TR><TR><TD CLASS="quote">ive seen a car go from 208 to 212whp with a simple adjustment of a v-afc..and get this..it was a honda
who the hell is "stick" anyways?..probally a dsm lover </TD></TR></TABLE>
yeah "stick" why don't you explain why these people are seeing gains with their vafc.
Old May 13, 2004 | 06:56 AM
WAFFLES's Avatar
Default Re: (VAAJ)
I gained 13whp and 13ft-lbs at 5700rpm by dropping my vtec and cleaning up my a/f a bit.....yeah I hate my vafc.
It may not adjust timing, but I have a mugen programed ecu, so adjusting the fuel helps quite a bit.
Old May 13, 2004 | 07:46 AM
spaceman's Avatar
interesting post...im gona go with hondata..someone should dyno an afc on a completly stock motor,see what it does..if your adding mods and the afc then when you dyno and you get more power you cant say its from the afc..
Old May 13, 2004 | 09:24 AM
97L-esVeeTeg's Avatar
damn, you broke it down, thanx for the info,ill surely get hondata instead of a apexi vafc
Old May 13, 2004 | 11:19 AM
JsNA99si's Avatar
Default Re: (97L-esVeeTeg)
We were never compareing the hondata to the v-afc, i was just trying to get proof that the v-afc makes power. Of course hondata is better but also more expensive.
That would be an awesome thing to do dyno a hondata on a stock motor and a v-afc on a stock motor and see if the afc makes power.
Old May 13, 2004 | 12:15 PM
JerseySiPOS's Avatar
i have a vafc and do agree that hondata is better, of course.
but i have to say that i did a baseline run and made 159 hp.
did nothing but vafc tuning and came out with 175 hp.
This was all with keeping the cams at 0, 0 and no ignition timing test.
16 hp gain with vafc is not bad IMO.
Old May 13, 2004 | 12:27 PM
project_hatch1.8's Avatar
Default Re: (JerseySiPOS)
after tuning with a vafc my friends car made 10 more whp and 13 more ft.lbs. so i would say it helped
Old May 13, 2004 | 01:47 PM
H25's Avatar
H25
Default Re: (WAFFLES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WAFFLES &raquo;</TD></TR><TR><TD CLASS="quote">I gained 13whp and 13ft-lbs at 5700rpm by dropping my vtec and cleaning up my a/f a bit.....yeah I hate my vafc.
It may not adjust timing, but I have a mugen programed ecu, so adjusting the fuel helps quite a bit.</TD></TR></TABLE>
PUHAHAHAHAHAHAH YES please tell us how the vafc doesnt work.. Im dying to know.. where is mr J davis with his crazy ecu concoctions, im sure he would have been the first to talk **** and say that it doesnt work and to buy his stuff.. LOL
VAFC = Very cost effective..
Old May 13, 2004 | 01:57 PM
JsNA99si's Avatar
It cost more to dyno it then to get the actual part.
Damn i wish i had a dyno in my house, mine will be *** tuned for a while.
Old May 13, 2004 | 03:23 PM
like i said, i made 16 hp with no cam gear tuning, just fuel tuning vafc. thats pretty good on top of others that got better results too.
Old May 13, 2004 | 04:27 PM
spooned out's Avatar
interesting debate.... can a V-AFC help improve power gains????? If so is this good or bad??? any power gains are good of course but my question is whats the risk of runing AFC?????
Old May 13, 2004 | 04:40 PM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
Default Re: (spooned out)
hell after reading all that i think i'm going to buy a hondata
