knock sensor
Old May 11, 2004 | 09:08 PM
drewek-9's Avatar
Default knock sensor
ok do civic dx y-7 have an knock sensor on them
Old May 11, 2004 | 09:27 PM
drewek-9's Avatar
Default Re: knock sensor (civichbturbo2000)
bump anyone
Old May 11, 2004 | 10:31 PM
robtec's Avatar
i believe that all obd-2 civics use ks
Old May 11, 2004 | 10:56 PM
drewek-9's Avatar
Default Re: (robtec)
u know where they are located at ?
Old May 12, 2004 | 05:15 AM
T.J.'s Avatar
Default Re: (civichbturbo2000)
The knock sensor is on the back off the block. It will be above your ouil filter and to the left. To remove it you will need a 1 1/6 socket.
Old May 12, 2004 | 02:04 PM
nub's Avatar
nub
Default Re: (T.J.)
the y7 does not have knock sensor. there is however a threaded boss at the top of the block to thread one in if you have reason to
Old May 12, 2004 | 02:06 PM
senpai's Avatar
Default Re: (nub)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nub &raquo;</TD></TR><TR><TD CLASS="quote">the y7 does not have knock sensor. there is however a threaded boss at the top of the block to thread one in if you have reason to</TD></TR></TABLE>
you sir, are correct
Old May 12, 2004 | 02:18 PM
poison's Avatar
In OBD2, only the EX and Si had knock sensors along with a 2 wire IACV.
Old May 12, 2004 | 02:41 PM
Shaun's Avatar
Default Re: knock sensor (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">In OBD2, only the EX and Si had knock sensors along with a 2 wire IACV.</TD></TR></TABLE>
Old May 12, 2004 | 03:35 PM
teamsol's Avatar
Default Re: knock sensor (Shaun)
what does the IAVC stand for?
Old May 12, 2004 | 03:51 PM
Shaun's Avatar
Default Re: knock sensor (teamsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamsol &raquo;</TD></TR><TR><TD CLASS="quote">what does the IAVC stand for? </TD></TR></TABLE>
IACV * Idle Air Control Vavle
Old May 13, 2004 | 08:19 AM
teamsol's Avatar
oo alright thanks man.. do you know where that is located?
Old May 13, 2004 | 08:41 AM
Shaun's Avatar
on my b16 skunk2 IM its located on the back of it
92'si
Feb 8, 2010 06:27 PM
integg93
Aug 3, 2006 01:17 PM
Grnade
May 2, 2005 08:45 PM
CaptivaBlue
23
Mar 1, 2005 03:19 AM
