Need some information on a P07 delsol auto ECU?
Old May 11, 2004 | 08:25 PM
TurboB18C1's Avatar
Default Need some information on a P07 delsol auto ECU?
Could this ecu be chipped?
(it has a rom socket and a 74H... socket and a J1 and a CN2)
Can it be converted from auto to manual? (I know a resister has to moved)
If so , what things would i have to solder in and out to make it work?
I know most peole say it could not be chipped when i searched the board but some replys on the posts say it could be chipped.
The reason why i ask is i have couple p07s setting in my room and wanted to know if they are useful for hondata or uberdata or just a chip.
I already know of this website:
Old May 11, 2004 | 08:49 PM
RedZone's Avatar
Default Re: Need some information on a P07 delsol auto ECU? (TurboB18C1)
This is ecu is from a Honda Civic HB VX not a delsol. It unchipable, sorry.
Old May 11, 2004 | 11:31 PM
THE GAME IS THICK's Avatar
Default Re: Need some information on a P07 delsol auto ECU? (RedZone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedZone &raquo;</TD></TR><TR><TD CLASS="quote">This is ecu is from a Honda Civic HB VX not a delsol. It unchipable, sorry.</TD></TR></TABLE>
WRONG! That was my old ECU from my del sol si before i changed it from auto to manual. Do some research before you post bud...
Old May 11, 2004 | 11:43 PM
RedZone's Avatar
Default Re: Need some information on a P07 delsol auto ECU? (igotsol!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igotsol! &raquo;</TD></TR><TR><TD CLASS="quote">WRONG! That was my old ECU from my del sol si before i changed it from auto to manual. Do some research before you post bud... </TD></TR></TABLE>
If Im so wrong then hondata must be wrong too, right? http://www.hondata.com/techecuid.html
Your delsol Si must have had a VTEC-E engine in it then right? Last I checked your delsol Si would have had a p28 ECU and you can chip those all day long from auto to manual.
Here is a break down for your delsol model's
DelSol S = d15 engine (SOHC NON-VTEC 1.5l) with PO5 ecu
DelSol Si = d16z engine(SOHC VTEC 1.6l) With P28 ECU
DelSol VTEC = B16A engine (DOHC VTEC 1.6l) with P30 ECU
Is that enough research for you? a po7 ecu uses a 5 wire O2 sensor as well but I guess your delsol had one of those too right? before you start to put some one down for trying to help another person out , do some research.
Modified by RedZone at 12:57 AM 5/12/2004
Old May 11, 2004 | 11:53 PM
"Stupid Flanders, you're a genius"
Old May 11, 2004 | 11:59 PM
RedZone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igotsol! &raquo;</TD></TR><TR><TD CLASS="quote">"Stupid Flanders, you're a genius"</TD></TR></TABLE>
Thanks Homer
Katman, your the one that took the picture can you put some insight on this for us please.
Old May 12, 2004 | 01:28 PM
Katman's Avatar
yeah, that specific type of P07 ecu isn't too chipper friendly. I've tried reprogramming them in the past, but they run like ***. However, there are peeps on the pgmfi phorum that were more successful than I in making this version of the P07 work on a reprogrammed chip.
And just some FYI...
There are 2 types of P07 ecu's. One is the not-so-chipper-friendly type shown above with the board number of "02D01560-1500".
The other type of P07 ecu is a bit rare, but is EXACTLY like a P28's board layout, with either one of these numbers:
"02D011F0-1500"
or
"02D01720-1500"
..this slightly rare P07 can be reprogrammed in the same exact manor as a P28 ecu.
HTH...
Old May 12, 2004 | 09:06 PM
TurboB18C1's Avatar
Default Re: (Katman)
Thanks for your repleys
pip9
37
Jul 5, 2015 06:19 AM
balbowskie
Aug 24, 2012 03:56 AM
teg01type-r
Jan 3, 2007 03:20 AM
hypa
Mar 26, 2004 09:58 PM
