HF transmission
Old May 11, 2004 | 08:22 PM
jackzzz's Avatar
Default HF transmission
Does the HF transmission have a higher 5th gear ratio?
Old May 11, 2004 | 08:49 PM
DreamAccord's Avatar
Default Re: HF transmission (jackzzz)
i know it has a higher 2nd because i had a civic 4 dr and put a HF tranny in it and it would do 90 in 2nd gear........holla
Old May 11, 2004 | 09:14 PM
junkyardRx's Avatar
aaaaaaaallllllllllll theeeeeeeeeee geeeeeeeaaaarrrsss aaaaaarrrreeeee loooooooooooooooooooooooooooooooongggggg. i have it on my sohc zc. i'm about to swap it out for an si tranny causeeeeeeee iiiiiiiimmmm tiiiiiiiiiired ooooooooooooooooooffff theeeeeeee loooooooong gearsssssssssssssssssssss.
Old May 12, 2004 | 06:13 AM
jackzzz's Avatar
Default Re: HF transmission (katsumoto)
Kat wanna sell that tranny to me when you pull it?
Old May 12, 2004 | 08:52 AM
junkyardRx's Avatar
i would but i dont wanna go thru the hassle of packing n shipping that heavy thing all the way there to texas man. sorry. i'll probably just trade it here for a case of corona and a pack of newports. are you going forced induction or hybrid transmission?
Old May 12, 2004 | 09:00 AM
FlexW99's Avatar
HF is 4 speed, not 5.
and yes the gears are longer to compensate.
Old May 12, 2004 | 09:11 AM
ImprtTuner88's Avatar
Default Re: HF transmission (FlexW99)
i have an HF tranny that has 5 gears!
and the 4spd came in the STD hatches............
Old May 12, 2004 | 09:28 AM
FlexW99's Avatar
Default Re: HF transmission (ImprtTuner88)
shows you how much i know
i assumed it was a hatch.
Old May 12, 2004 | 09:45 AM
jackzzz's Avatar
Im just restoring a Si to daily drive to save on gas , I drive a 02 Turbo cummins diesel that makes about 500hp and a Shelby GLHS turbo that makes around 250hp. So im not really worried about performance. I like the looks of the CRX and i drive around 80k miles a year or more so i needed something that would be fun to drive ,cheap, and reliable. The Shelby is a collectable numbered car so i dont drive it much.
I will post some pics of my progress after my 20days is up. I have rebuilt the drivetrain and it has a D16 ,springs , exhaust, cold air ,Im working on the body so i can paint.
Thanks.
Old May 12, 2004 | 10:09 AM
crxzcracer's Avatar
From: Murfreesboro, Tennessee, United States of America
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlexW99 &raquo;</TD></TR><TR><TD CLASS="quote">shows you how much i know
i assumed it was a hatch. </TD></TR></TABLE>
I got a hf hatch -crx- its a 5 speed
my hf tranny with a dohc zc kills the gears tho but i have never seen how fast it would be with an si
Old May 12, 2004 | 10:50 AM
4g4drb17's Avatar
Default Re: HF transmission (crxzcracer)
check this link out http://www.knology.net/~jedikl...s.htm
Old May 12, 2004 | 12:33 PM
junkyardRx's Avatar
yeah well honda didnt make a civic hf.
Old May 19, 2004 | 06:54 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by katsumoto &raquo;</TD></TR><TR><TD CLASS="quote">yeah well honda didnt make a civic hf.</TD></TR></TABLE>
nope.............unless you put an 8valve in your hatch for some mpg action!
Old May 19, 2004 | 07:31 PM
JohnnieChimpo's Avatar
'89 CRX HF 90 miles an hour is 3000rpm tested it yesterday.
I like the gears in the car if only it had about 3 times the power it has (62hp).
BTW '87 GLHS is very cool. I have an '88 CSX-T 2.5 20psi S60.
Old May 20, 2004 | 04:43 AM
tolnep's Avatar
Default Re: HF transmission (JohnnieChimpo)
I have a 91 hf and I have always wondered how the hf tranny would work with a turbo'd b18c dart block pushing 300+ hp at the wheels.. Maybe 300mph in 5th?
This is a partially honest question since I am considering a build. But I assume the hf tranny is not strong enough to take the punishment.
Old May 20, 2004 | 04:53 AM
Dave421's Avatar
Default Re: HF transmission (tolnep)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tolnep &raquo;</TD></TR><TR><TD CLASS="quote">wondered how the hf tranny would work with a turbo'd b18c dart block</TD></TR></TABLE>
There's your problem. The D & B-series stuff is not interchangeable. Basically nothing is interchangeable between the different series as far as major parts go (D, B, H, F, K, A-series). Only things that swap over are throttle bodies and stuff like that.
Old May 20, 2004 | 10:01 AM
junkyardRx's Avatar
Default Re: HF transmission (Dave421)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave421 &raquo;</TD></TR><TR><TD CLASS="quote">
There's your problem. The D & B-series stuff is not interchangeable. Basically nothing is interchangeable between the different series as far as major parts go (D, B, H, F, K, A-series). Only things that swap over are throttle bodies and stuff like that.</TD></TR></TABLE>
in other words, it's not possible. but i believe that the LS tranny has the longest gears in B series.
bLuBoOrEx89_RAZORS_
28
Nov 27, 2007 03:22 PM
bigwill_2004
Jun 14, 2006 07:15 PM
AZTEKEF9
15
Dec 10, 2004 06:39 PM
out_of_order
Jul 6, 2004 10:46 AM
blah13
Oct 11, 2003 07:40 PM
