head swap
would a vtec head from a 94-up integra fit onto a 92 integra gs block? all i ever hear about is the vtec head with the ls block but i wana know if i can do it with the gs block. if it doesnt fit, whats the difference? i would appreciate some help. thnx
It's called LS/VTEC. There's about 20 people within the last 5 days that asked the same exact questions. I swear there should be a sticky.
But yeah, Any vtec head will work fine with any other B-series block as long as you know what you are doing. From the sound of your post, you might wanna spend a good 3-4 weeks of research even before thinking about considering opening your door to pop the hood latch.
the gs motor is the same as the ls motor. its the exact same procedure as an ls-vtec.
this is a good thread, but unfortunately, ive had to refer to it many times because people dont search.
https://honda-tech.com/zerothread?id=501372
