Wierd Metal Scraping Sound (Clutch?)
Old May 11, 2004 | 07:46 PM
Midnight_R's Avatar
Default Wierd Metal Scraping Sound (Clutch?)
I recently installed a new OEM GSR clutch. When I am driving in 5th gear, around 60 mph maybe 2500-3500 rpm range, not really sure, I press the gas and metal scraping sound is coming from somewhere. Let off the gas- it goes away. Step on the gas - sound comes back etc. The sound dosnt always reappear. What could it be?
Old May 12, 2004 | 12:11 PM
Bay_707's Avatar
i have had this problem before actually... then it slowly went away... i hope to god it wasnt the clutch : ( Hmm it could be actually... it sounds more like a rattling though, and mine only happens at 2200 rpms... every time it will rattle at 2200 rpms... The rattling sounds a lil dif than the scraping, i thought it was something hard in the break pads that you occasionally get. Anyways bump for a solution/answer.
Edit: I was also told by a shop that the rattling noise was an exhaust hanger... but it was coming from the engine bay so i duno.
Old May 12, 2004 | 12:58 PM
SamC's Avatar
Default Re: Wierd Metal Scraping Sound (Midnight_R)
what other mods do you have? I had a scarping sound after the cat back install and found out that it's the heat shield.
Zeino
Mar 30, 2011 01:36 PM
RTW DC2R
Oct 8, 2006 08:10 PM
Fugun
Dec 31, 2004 02:33 AM
LFE142
Mar 25, 2002 03:04 PM
