Type R cams, you'll need LMA's in yer' 10+ year engine....
Old May 11, 2004 | 07:15 PM
Overkll's Avatar
Default Type R cams, you'll need LMA's in yer' 10+ year engine....
Just installed the type r cams. Lost motion assemblies were ALL shot , all very loose and some were sticking down. It's really not worth installing cams without replacing the LMA's. Use new B16 ones ($) or type r ones ($$$$). You'll have to remove the rockers though. Don't even ask how we did it in my car (they hit the frame in a B16 EF with Hasport mounts.) Not for the faint of heart. IM me if you really need to know
Later, Overkll
Old May 11, 2004 | 07:23 PM
johnjw's Avatar
Default Re: Type R cams, you'll need LMA's in yer' 10+ year engine.... (Overkll)
I dont understand why your mounts and hitting the frame have anything to do with lost motion assembleys?
Old May 11, 2004 | 07:52 PM
b16_madman's Avatar
I've heard it a few times but what parts are the LMA's? Just for my knowledge. Remove rockers? dang, i'm a motor moddin noob
Old May 11, 2004 | 08:14 PM
bryant's Avatar
It's not a must. I had CTR cams in my old B16a and they worked perfectly fine. Just depends how old, or should I say, how beat on your motor is/was. Not everyone needs to do it.
Old May 11, 2004 | 08:19 PM
kid-honda's Avatar
Default Re: Type R cams, you'll need LMA's in yer' 10+ year engine.... (johnjw)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnjw &raquo;</TD></TR><TR><TD CLASS="quote">I dont understand why your mounts and hitting the frame have anything to do with lost motion assembleys?</TD></TR></TABLE>
I agree WTF?
Old May 11, 2004 | 08:35 PM
0554's Avatar
uhm all i got from this was you installed itr cams and replaced your lma's, i was lost after that
Old May 11, 2004 | 08:39 PM
SC0TT's Avatar
LMAs are bank..I got quoted like $215 for all of them. Bad LMAs are why a lot of b16's tick the way they do.
Old May 11, 2004 | 09:05 PM
michael O's Avatar
Default Re: (SC0TT)
Something is seriously wrong if the rockers are out of the engine and hitting the frame of your car.
Old May 11, 2004 | 10:02 PM
KoRE's Avatar
he is saying when you remove the shafts for the rocker arms they will hit the body so you can't remove them all the way. which makes it hard to get all the LMA's out
A cheaper route would be to go Prelude LMA's w/ a spacer about $70 all together...
look for a post by omniman
Old May 12, 2004 | 07:17 AM
johnjw's Avatar
Default Re: Type R cams, you'll need LMA's in yer' 10+ year engine.... (KoRE)
Oh
&lt;never taken head apart in car
Old May 12, 2004 | 07:19 AM
RobbieG35's Avatar
12 Years Strong
My CTRs have had several accidental 10K revs, and the LMAs are fine
Old May 13, 2004 | 05:49 AM
Overkll's Avatar
Default Re: Type R cams, you'll need LMA's in yer' 10+ year engine.... (HybridHatch88)
Sorry for the confusion. The rocker shafts have to be removed to get the LMA's out. The shafts run parallel and below the camshafts and slide out of the head towards the driver's side mount. They just clear the mounts, but will not clear the body of the car. Read up on the function of the LMA's . Mine were very beat up, not sure how others are. BUT I beat up the motor VERY well with track days/autox/hitting vtec in every gear. I've read that bad LMA's can lead to broken cams (not from experience though )
Later, Overkll
(BTW, I got the type R LMA's at dealer cost, I would NEVER buy them new at retail!)
Old May 13, 2004 | 06:12 AM
spaceman's Avatar
how much$?..how can i get it at dealer cost?
Old May 13, 2004 | 06:13 AM
hondahans's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KoRE &raquo;</TD></TR><TR><TD CLASS="quote">A cheaper route would be to go Prelude LMA's w/ a spacer about $70 all together...
look for a post by omniman</TD></TR></TABLE>
Deffinately.
Old May 13, 2004 | 08:11 AM
KoRE's Avatar
Default Re: Type R cams, you'll need LMA's in yer' 10+ year engine.... (spaceman)
try contacting Len on this board he can help you out.
Old May 13, 2004 | 08:20 AM
EL Vap133's Avatar
I just had to replace one LMA a little bit after I got my ITR cams. No more problems since.
Old May 13, 2004 | 09:27 AM
Overkll's Avatar
Dealer cost=know somebody from a shop or at the dealership.
Later, Overkll
Old May 13, 2004 | 10:26 AM
spaceman's Avatar
cool
Old May 13, 2004 | 10:38 AM
BlueShadow's Avatar
Default Re: Type R cams, you'll need LMA's in yer' 10+ year engine.... (B16_madman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16_madman &raquo;</TD></TR><TR><TD CLASS="quote">I've heard it a few times but what parts are the LMA's? Just for my knowledge. Remove rockers? dang, i'm a motor moddin noob</TD></TR></TABLE>
LMA = Lost Motion Assembly
A new LMA from the dealer costs about $32 for ITR and $28 for Lude Civic SI. For DOHC VTEC's you'll need a total of 8 of them not 16 as I said before.
For SYSTEM COMPONENT scroll down and chose "VALVE-ROCKER ARM"
http://www.acuraautomotivepart...cgry5=
Modified by BlueShadow at 1:11 AM 5/14/2004
Old May 13, 2004 | 11:56 PM
KoRE's Avatar
Default Re: Type R cams, you'll need LMA's in yer' 10+ year engine.... (BlueShadow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueShadow &raquo;</TD></TR><TR><TD CLASS="quote">
A new LMA from the dealer costs about $32 for ITR and $28 for Lude Civic SI. For DOHC VTEC's you'll need a total of 16 of them.
http://www.acuraautomotivepart...cgry5=</TD></TR></TABLE>
The prelude LMA's are no where near $28 more like $7-9 a piece....
Old May 14, 2004 | 12:12 AM
BlueShadow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KoRE &raquo;</TD></TR><TR><TD CLASS="quote">The prelude LMA's are no where near $28 more like $7-9 a piece.... </TD></TR></TABLE>
Is that new or used?
Old May 14, 2004 | 12:14 AM
KoRE's Avatar
Brand new
you need to use a specific size spacer for them to work properly though...
I got the info from a post on Omniman
Old May 14, 2004 | 12:28 AM
BlueShadow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KoRE &raquo;</TD></TR><TR><TD CLASS="quote">Brand new
I got the info from a post on Omniman </TD></TR></TABLE>
That's strange, I also did a search on another online parts store and it does have the LMAs listed at $7 ea, as opposed to $28. The $28 price tag from http://www.hondaautomotiveparts.com looks like it is the price for a set of 4 LMA's since their price of $28 divided by 4 = $7. Another weird thing is that one of the old threads that came up from a search said that the $28 price was also quoted by somebody that worked at a Honda dealership!
Old May 14, 2004 | 12:55 AM
Keebler's Avatar
Can someone post some pics of these LMA's? Id like to see what exactly we are talking about here. I thought I knew what they were, but maybe im confused...
Old May 14, 2004 | 02:01 AM
SiR Kid's Avatar
New User
Default Re: Type R cams, you'll need LMA's in yer' 10+ year engine.... (Keebler)
Lost motion assemblies... it's the hydraulic lifter thing in the middle for each cylinder's VTEC rocker in a DOHC VTEC valvetrain...
