Fuel Pump Issues with a STD hatch back Motor swap RRRRRRRR
I have a std 4 speed with an CTR swap.
When I gas it the car hesitates badly like its running out off fuel
all his **** started happening after I Installed the aem fuel pressure regulator and fuel rail I have set it too 44psi on the fuel rail.
umm what can be fuel pump on the std is fucked?
it didnt used to do this **** before..
with the engine idling the fuel pressure should be around 28-32 psi. not 44!
then @ WOT (can be simulater by removing vac line from FPR) fuel pressure should be 38-40psi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si »</TD></TR><TR><TD CLASS="quote">with the engine idling the fuel pressure should be around 28-32 psi. not 44!
then @ WOT (can be simulater by removing vac line from FPR) fuel pressure should be 38-40psi</TD></TR></TABLE>
it still happens
it still happens
pretty obvious situation if you ask me. it is what it seems to be. put a walbro 255 in there, you should have put one in there from the start.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red civic standard »</TD></TR><TR><TD CLASS="quote">I ran a type R engine with my standard fuel pump last season...ran fine.
upgraded to a Walbro 255 for this season.
umm did u have a fpr and fuel rail installed on the old fuel pump??
cause stock I am sure its fine but when u get the fpr and fuel rail thats when it happens..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red civic standard »</TD></TR><TR><TD CLASS="quote">no fpr or fuel rail when I ran my stock pump.
yups thats why u didn't have any problems
someone else wanna shed some light on my problem
My B&M guage reads 38 PSI at idle. I have a stock B16 FPR, just in case you're curious. I bet that crappy STD fuel pump is about to take a dump. Try upgrading it to a 190 lph.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. S »</TD></TR><TR><TD CLASS="quote">My B&M guage reads 38 PSI at idle. I have a stock B16 FPR, just in case you're curious. I bet that crappy STD fuel pump is about to take a dump. Try upgrading it to a 190 lph.</TD></TR></TABLE>
I think soo it takes forever to start also I am gussing its the fuel pump also
28-32 is only for a d16 not a b series
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89civicdx »</TD></TR><TR><TD CLASS="quote">
28-32 is only for a d16 not a b series</TD></TR></TABLE>
yups.
bseries is 47-54psi
thats a lot off psi for a fucken 2injector car
yups.
bseries is 47-54psi
s1ngleslam
Oct 21, 2008 12:37 AM
superhatchbackbros
Oct 7, 2006 10:51 PM
Louie_EM1
May 15, 2004 01:12 PM
