Wiring 02 Sensor questions
Well, ive always wondered why sometimes I throw a code 1 if I travel long distances, until I took a look at my wires.. I dont even have a wire connected to the o2 sensor.
BTW , this is DOHC ZC. Im curious if I just half to run the wire coming from the O2 to the ecu, or do I half to run power to it?
You may find this link helpful...
https://honda-tech.com/zerothread?id=468260
It has some good flow charts for diag. that may help you figure out which pin you need to run the wire to ect...
hrmm, I think it would be helpful.. if you slowed down a little and read the msg.
I know where it goes, because theres a wire coming from the ecu that has notthing attached, and, I have a diagram of the wires to the ecu :]
I appriciate the link though, zcivic has tons of good posts.
Do I just wire the o2 sensor to the ecu? thats it?
Acc3l3ratoR
May 1, 2019 07:41 PM
