Type R piston rings..?
Old May 11, 2004 | 05:15 PM
Jmorin's Avatar
Default Type R piston rings..?
I am possibly getting a b18c5 with some other goodies at a price i can't refuse but it needs new piston rings cause the compression on it is screwed up. Is this the only problem? also how much would it cost to replace the rings?
Old May 11, 2004 | 05:49 PM
Mr_CRX's Avatar
Default Re: Type R piston rings..? (Jmorin)
I just ordered new OEM rings for my GSR for $110 from http://www.acuraautomotiveparts.org
You might find them for a little less, but the prices I've usually seen have been 100-120.
Old May 11, 2004 | 08:57 PM
PHiZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jmorin &raquo;</TD></TR><TR><TD CLASS="quote">I am possibly getting a b18c5 with some other goodies at a price i can't refuse but it needs new piston rings cause the compression on it is screwed up. Is this the only problem? also how much would it cost to replace the rings? </TD></TR></TABLE>
You have to factot in, if the compression is bad, it could also be valves, or there could be cylinder wall scuffing more likely.
-PHiZ
ZCHondaCRX91
Engine Machining & Assembly
Sep 14, 2015 04:23 PM
EJ8chu
23
Jul 13, 2012 06:15 PM
PARADOX_sf
Jan 3, 2011 05:42 PM
EJ8chu
Jun 16, 2008 05:26 PM
Vpenh
Aug 8, 2006 02:49 PM
