93 ls motor and 94+ ls motor ?
Old May 11, 2004 | 04:44 PM
slowr6's Avatar
Default 93 ls motor and 94+ ls motor ?
Modified by slowr6 at 4:54 PM 9/1/2007
Old May 11, 2004 | 09:43 PM
slowr6's Avatar
Old May 11, 2004 | 10:03 PM
triggerX's Avatar
Default Re: 93 ls motor and 94+ ls motor ? (slowr6)
If I can recall the 91 Integra LS motors are differen't from the 94-01 Integra LS motors. The 90-91 Integra LS motors are 1.7 liters and the 94-01 are 1.8L.
Old May 12, 2004 | 06:13 AM
DaX's Avatar
DaX
Loved
Community Favorite
Driver side mount is different.
Thermostat housing is different.
Slight differences in the heads but not enough to care about IMHO if you're going to boost.
Old May 12, 2004 | 10:46 AM
electric-boost's Avatar
Default Re: (DaX)
well 91 is obd0 and 94 is obd1
the b18a from the 91 is a 1.8ltr hence i being called b18(the 92-93 gsr is the 1.7ltr using the b17)
the only difference between the older and newer is the valvetrain. 10 more hp and redlines to 6.8k instead of the old 6.5k, not much of a difference at all
Old May 12, 2004 | 11:00 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: (electric-boost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1Chance &raquo;</TD></TR><TR><TD CLASS="quote">If I can recall the 91 Integra LS motors are differen't from the 94-01 Integra LS motors. The 90-91 Integra LS motors are 1.7 liters and the 94-01 are 1.8L.</TD></TR></TABLE>
WRONG. Don't spread misinformation.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by electric-boost &raquo;</TD></TR><TR><TD CLASS="quote">well 91 is obd0 and 94 is obd1
the only difference between the older and newer is the valvetrain. 10 more hp and redlines to 6.8k instead of the old 6.5k, not much of a difference at all</TD></TR></TABLE>
WRONG. The B18B ECU [OBD1 P75] Redlines at 7200, the B18A ECU redlines at 6800.
Old May 12, 2004 | 11:04 AM
Default Re: (DaX)
ok well since i didnt say anything about the ECU lets assume i was just talking about the tach. by reading his I decided not to get to tech. I would have to say that we are both indeed correct
Old May 12, 2004 | 11:06 AM
DaX's Avatar
DaX
Loved
Community Favorite
Uhm, the ECU is what limits the RPM's...the Tachometer is just a visualization. Either way the A1's are redlined at 6800 and the B1's are redlined at 7200, but I take my A1 to 7200 occasionally with no problems.
1a
Oct 13, 2007 08:23 AM
my hatch
Nov 27, 2005 03:21 PM
Mr. Travis
Apr 7, 2004 08:30 PM
91sleeper
Sep 2, 2003 04:30 PM
