ek type r time slips
Old May 11, 2004 | 03:24 PM
JBk24crx's Avatar
Default ek type r time slips
i dont have a scanner, so i just type the times. The usdm itrmotor is stock ,except for the I/H/E and 20/8/13 mh slicks, the only problem i had was that my e-brake was broke,so no good burn-outs were taken. and no tach nor shift light. i need to know what im doing wrong. advice please!!
this my first time slip:
My time---------------------------Other guy
RT -.013 ------------- R/T +.384
60ft 2.172 ------------- 60ft 2.513
1/8 9.140 ------------- 1/8 10.135
mph 78.12 ------------- mph 71.54
my second slip:
My time------------------------My friend's time
R/T +.265 ------------ R/T +.000 (perfect reaction of the night)
60ft 2.103 ------------ 60ft 2.453
1/8 8.943 ------------ 1/8 10.179
mph 78.91 ------------ "no mph info"
Modified by JBLSVTEC at 1:20 AM 5/12/2004
Old May 11, 2004 | 11:11 PM
JBk24crx's Avatar
Default Re: ek type r time slips (JBLSVTEC)
ttt
Old May 12, 2004 | 08:59 AM
streetlvlhatch's Avatar
you need to get better 60ft's which is probably attained by launchin from a higher rpm. Also, a tach is essential. When do you know when to shift?? You can def. get some better times imo!
Old May 12, 2004 | 10:16 AM
JBk24crx's Avatar
Default Re: ek type r time slips (streetlvlhatch)
I was launching from 7500 to 8000rpmwith 22x8x13 MH slicks.my 60ft sucked because i couldnt do a proper burnout because of my ebrake not working.my best was my second run which was 8.9 with a shitty 2.160ft.I already purchased a tach,so thats taken care off,and the ebrake is finally fixed.anybody have anymore advice.this was only my third time at the track and first time with slicks.
Old May 12, 2004 | 05:58 PM
madhatch's Avatar
I run consistant 8.90 with a 2.2 60 foot time. on nitto 555 'rs
84 mph
Old May 13, 2004 | 09:02 AM
Griffin@Camtech's Avatar
launch higher, fix the e-brake and get the tires hot, switch to 22/8/13 slicks and get a tach.
JBk24crx
Jun 18, 2004 07:53 PM
JBk24crx
Jun 16, 2004 12:53 PM
Stellar1
14
Nov 25, 2003 02:14 PM
itrsport.com
Nov 12, 2001 10:31 AM
