ITR lug pattern? Will this fit?
+50 mm offset, 5x114.3 lug pattern
19 mm lugs
19 mm lugs
19 mm lugs
+50mm offset only if the rim has a width of 6". With increasing width of the rim, your offset will decrease. i.e. 7" width usually needs +42mm offset for ITR's.
19 mm lugs
Not true. I run 16 x 7 Mugen Mf-10s with 225/40-16 Pirellis on 50mm offset with no rubbing. With 42-43mm offset you can only run a 215 width max.
RacerBoy
Dec 9, 2002 04:43 AM
