setting my b&m fpr
Old May 11, 2004 | 09:28 AM
hi mom's Avatar
Default setting my b&m fpr
Okay well I just recently got my swap back and the Technician set my B&M Fuel Pressure at 32 on idol, and 42 when vacum hose is off? He said its right, but it seems kinda low... because I had my car on 42 at idol before..
What should it be at?
Old May 11, 2004 | 09:34 AM
tilt's Avatar
Default Re: setting my b&m fpr (Kid RS)
on my gsr it was 40psi stock with vacuum hose on, 50psi with hose off.
Old May 11, 2004 | 09:35 AM
hi mom's Avatar
Default Re: setting my b&m fpr (tilt)
wont it run wayy to rich on that high of a setting? sorry I dont know much, but seems way off from mine..
Old May 11, 2004 | 09:39 AM
tilt's Avatar
i have it currently set at 50psi with hose on. it's running mad rich... im gonna bump it down soon. hth
Old May 11, 2004 | 09:42 AM
hi mom's Avatar
hmmm
any others?
Old May 11, 2004 | 10:02 AM
milo's Avatar
Old May 11, 2004 | 10:10 AM
hi mom's Avatar
Default Re: setting my b&m fpr (milo)
Yeah but what do I set it at..
My car is B18B1 bottom with B16 Head?
Do I have it set right at 32psi with hose on, or should it be up more because its vtec head now?
Old May 11, 2004 | 10:13 AM
SuzukaBlueAP2's Avatar
We can just tell you what to set your fuel pressure at. It's all relative to your setup and your current A/F ratio. Stock fuel pressure should be around 34-36 under vacuum and 38-40 atmospheric. **edit** correct stock fuel pressure levels are above.
I've got the B&M FPR on mine, and it is 43 under vacuum and 46-48 atmospheric.
I'm personally going to ditch the B&M here soon and get a different unit that is a 'rising rate' FPR. This is only because I am turbocharged, so I want the pressure in the fuel system to overcome the pressure going into the motor.
Anyways...back on topic...as simple as the fuel pressure regulator seems, in order for it to properly work with whatever your setup is, you need to take it to a dyno and tune it according to your A/F curve.
Old May 11, 2004 | 10:25 AM
greaseball's Avatar
Default Re: setting my b&m fpr (ScreaminTeg)
dyno is the key. my built gs-r is @ 42psi under vacuum and @ 61psi wot (atmospheric). it's been tuned 3 different times by 3 different tuners and that is the only thing that has never changed.
Old May 11, 2004 | 11:20 AM
hi mom's Avatar
Default Re: setting my b&m fpr (greaseball)
yeah, he said he did it on the dyno aswell as my cam gears, so I guess its set properly, thanks guys
Old May 11, 2004 | 11:24 AM
ebelp's Avatar
Helms.
hybrid98
Aug 15, 2007 12:54 PM
[HrZn]4life
Apr 2, 2003 12:37 PM
Kolijian
Jul 4, 2002 09:12 AM
TakaIntegra
Jun 18, 2002 06:30 AM
zcivic91
May 14, 2002 03:09 PM
