FS: parting out B18A and B17 blocks, cranks, rods, oil cooler, obd0 harnesses, dizzy, rings, gaskets
Old May 11, 2004 | 09:06 AM
owen_the_soyboy's Avatar
Default FS: parting out B18A and B17 blocks, cranks, rods, oil cooler, obd0 harnesses, dizzy, rings, gaskets
Selling some stuff to start a new non-Honda project, so all of this stuff has gotta GO...!
<U>All prices are INCLUDING SHIPPING </U>
I prefer Paypal and US Postal money orders. Thanks, Owen
<U>B16 oem lower gasket set - $40</U>
New and unused, still in packaging
<U>B16A wire harness - $50</U>
Complete, uncut, excellent condition from a jdm 1st Gen 5 speed obd0 B16 Civic.
<U>B17A1 - bare block - $200</U>
Shortblock includes - oil pump, end cover, mains, oil squirters
*Requires- o/s bore & hone
<U>B17A1 - block parts, all used, most have 90k miles</U>
Oil cooler, water pipe, special oil cooler bolt - 65
Shaved OEM crank pulley (1 rib left, like CTR N1) - 50
Timing belt gear, washers - 10
Thermostat and housing - 20
Headbolts, torqued once, same as B16 parts - 20
Water pump, used - 20
Clutch, pressure plate, some life left - 50
Flywheel, exc. condition stock part - 40
Oil pan - 50
Windage tray - 15
Oil pickup - 15
<U>B18A1 - LS auto '91 wire harness - $50</U>
Complete, excellent condition, uncut
<U>B18A1 - LS block parts, all used, most have 40k miles</U>
Water pipe, Thermostat, Thermostat housing, Water pump - 30
Shaved OEM crank pulley (1 rib left like CTR N1) - 50
Timing belt (used, ok) and crank gear and 2 washers - 40
Timing Belt Covers, top to bottom - 25
Alternator brackets - 15
Driver side engine mount bracket with studs - 15
Oil pan - 50
Windage tray - 15
Oil pickup - 15
Valvecover - 25
Head, complete / minus valvecover and cams - 55
Camshafts, could use as a core for regrinds too - 25
Camgears, bolts - 15
Intake manifold, fuel rail, injectors, obd0 - 40
Black box / oil separator - 15
Plug Wires - 15
<U>DIY ITB setup - $220</U>
2001 Suzuki GSX-R 750 motorcycle Individual Throttle Bodies (52mm inlet, 42mm at throttle plate) with secondary butterflies removed. Not disassembled yet, but these re the type that can be spread apart to space to match B series cylinder spacing. Comes with a B18C1 GSR intake manifold, cut 3" from head flange so the fuel rail studs are still in tact.
<U>'92-'95 Civic Si/EX OEM Honda Front Lip- $60----&gt; S O L D ! ! </U>
Good condition, no mounting bolts/nuts but thats easy to get at any hardware store.
<U>D16A6 CRX Si cable tranny - $125----&gt; S O L D ! ! </U>
Works fine but has the usual issue of being stubborn to get in 3rd when shifting at high revs. Around 90k miles on it, just swap in a new synchro set from BERT-O or drive it as-is if you are not racing.
<U>obd0 LS B18A distributor - $100----&gt; S O L D ! !</U>
Great condition
<U>OEM B-series rings, standard size - $95 - - &gt; SOLD !</U>
New and unused, in boxes, full set for 4 cylinders
<U>B18A1 - LS crank/rods - $185 ----&gt; S O L D ! ! !</U>
Crank, rods, pistons, excellent condition
<U>B17A1 - crank/rods - $175----&gt; S O L D ! ! !</U>
Crank, rods, pistons still installed.
*Requires- polish crank on one rod journal from spun rod bearing
Modified by owen_the_soyboy at 8:32 AM 6/24/2004
Old May 13, 2004 | 10:24 AM
G3NR8's Avatar
Default Re: FS: parting out B18A and B17 blocks, cranks, rods, oil cooler, obd0 harnesses, dizzy, rings, gas
bizzump for Owen
Old May 15, 2004 | 07:58 AM
twentyfourseven's Avatar
where can i look into getting a new BERT-O syncro set?
Old May 16, 2004 | 08:02 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twentyfourseven &raquo;</TD></TR><TR><TD CLASS="quote">where can i look into getting a new BERT-O syncro set?</TD></TR></TABLE>
BERT-O is the "user name" of ther guy on here at Honda-Tech that works at Gettel Acura down in Florida. he rocks
Old May 17, 2004 | 02:51 AM
thanks
Old May 17, 2004 | 12:31 PM
kaptr1d's Avatar
LS Cranks & Rods are SOLD.
Check ur paypal, ;]
Old May 26, 2004 | 07:18 PM
kaptr1d's Avatar
i recieved the crank, ls rods, pistons.
the packaging was excellent.
thank you owen.
VOUCH. bump.
Old May 28, 2004 | 01:35 PM
sauceracer247's Avatar
hey do you still have the b 17 crank? if so let me know thanks
Old Jun 2, 2004 | 08:05 AM
B17A1 - crank/rods - $175<U>----&gt; S O L D ! ! !</U>
Modified by owen_the_soyboy at 1:51 PM 6/18/2004
Old Jun 5, 2004 | 08:58 PM
DohcVtecCrx's Avatar
hmm if you really want to sell stuff maybe try answering your e-mail
Old Jun 7, 2004 | 04:51 AM
wha wha wha?
I do answer emails, maybe yours never got thru.... why not PM me or respond in the thread....?
-Owen
Old Jun 8, 2004 | 05:23 AM
I seen your post on RM friend of mine needs some ls parts...cams, cam gears and distrib (obd-0)
Old Jun 8, 2004 | 01:24 PM
I lost my password on RM and am in the process of getting back in there, my work email BLOWS and of course it wont let the password email thru, wtf...
why not email owen_the_soyboy@yahoo.com or PM me here?
argh!
Old Jun 8, 2004 | 04:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DohcVtecCrx &raquo;</TD></TR><TR><TD CLASS="quote">I seen your post on RM friend of mine needs some ls parts...cams, cam gears and distrib (obd-0)</TD></TR></TABLE>
Umm yeah if you read the above...my friend needs LS parts
CAMS, CAM GEARS and DISTRIBUTOR
Old Jun 18, 2004 | 06:44 AM
limpy's Avatar
hey do you hve a complete ls longblock? would be interested if you do let me know.
Old Jun 18, 2004 | 09:50 AM
NOPE, I bought one but then parted it out. A friend of a friend hydrolocked his GSR swap so he is buying my bare LS shortblock.
Modified by owen_the_soyboy at 9:13 AM 6/26/2004
Old Jun 26, 2004 | 05:11 AM
ttt
Old Jun 28, 2004 | 04:36 AM
Old Jun 28, 2004 | 05:55 AM
6SPD_EK's Avatar
bump for a great seller startin' a new project????
Old Jun 28, 2004 | 08:01 AM
thanks!
new project? MEEEEEEEEE? yes... dropping an "LS1" all-aluminum 350 cu.in. V8 and "T56" six speed tranny out of a 97-02 vette/camaro/firebird into a 2600 pound 1987 Mazda RX7
my buddy in town already has his LS1FC done. Bnjmn here is doing one also. I cant fawkin WAIT !
guymosiris
May 1, 2013 01:18 PM
SLVRSTN_DC4
Nov 7, 2006 05:28 AM
TheBobFather
Jun 22, 2005 02:35 PM
