Vacuum leak that goes away when engine is warm...
Old May 10, 2004 | 10:57 PM
GapxGuy's Avatar
Sushi Buffet Champion
Default Vacuum leak that goes away when engine is warm...
When I start up the engine, it revs up a bit over 3k RPM, bounces up and down from 1,500-3,000 RPM and slowly goes away when engine is fully warm. Can anyone help? TIA
Old May 11, 2004 | 07:26 AM
Rtype16's Avatar
Default Re: Vacuum leak that goes away when engine is warm... (GapxGuy)
Broken or clogged idle air control motor.
Old May 11, 2004 | 11:03 AM
RedZone's Avatar
Default Re: Vacuum leak that goes away when engine is warm... (Rtype16)
what engine do you have? some engines have the throttle body that has a valve underneath it. it has a cover with to small bolts holding it on. take the cover off and you will see a brass nipple with a plastic ring. if the plastic ring has unscrewed itself then just screw it back in and put the plate back on and it will take care of your problem.
Old May 11, 2004 | 02:25 PM
GapxGuy's Avatar
I'm running a B20vtec with a GSR TB. Funny you mentioned the TB lower half, b/c I opened that piece trying to fix the vacuum leak. I opened it up and cleaned everything inside with carb cleaner. I found the vacuum leak, but may have make another one in atempt to fix the first one.
jumal
Sep 29, 2015 05:53 AM
DeCoY
May 19, 2014 07:54 AM
mikex1021
Apr 12, 2008 04:07 AM
KanDaMan
Mar 26, 2007 11:28 AM
