teg wont start?
Old May 10, 2004 | 10:33 PM
Ballinger's Avatar
Default teg wont start?
k i have been having some issues for a while now i have come to find out a few things
1. There is a vacuum hole inside the throttle body. It never closes so I believe that is my FITV, (fast idle thermo valve) or IACV (air idle control valve).
I cleaned the IACV out but not the FITV, so the motor idle surges from 1,000 to 2200 RPM when warm. When I first start it the revs are almost @ 4,000
2. There is a spring inside the distributor cap that is all twisted to hell ?
I am almost sure that something is wrong there. That's the ignition coil right?
Aso is there anything Icould visually see in the rotor to see if there is anything wrong w/it?
Tanks for you help........
Old May 10, 2004 | 10:43 PM
bleeedawg's Avatar
Default Re: teg wont start? (Ballinger)
replace the spring in the distributor. seems like you have a miss fire, which is causing unsteady idle. maybe a new distributor is needed. You can take urs in to the autoshops to test for defects.
Old May 11, 2004 | 07:34 AM
Ekasey's Avatar
Default Re: teg wont start? (bleeedawg)
the one in the tbody would be your FITV the lil stepper motor on the back of the manifold is your IAC try cleaning it out with brake clean and also make sure your throttle cable isnt holding the plate open, i dont belive the motor can rev up to 4000 without the throttle being open
Old May 11, 2004 | 10:08 AM
Ballinger's Avatar
Default Re: teg wont start? (eLusive ek4)
K, I was reading my helms manual @ breakfast this morning and I read that FITV are only on auT0 carZ y0! I have tommorw off so i will inspect it then. till then i will drive the buick park ave..............thanks for the input guys.
Old May 11, 2004 | 10:24 AM
Zerob16eg's Avatar
when you look at your rotor if their is alot of metal transfer or a burnt spot on it then it is a good idea to change it.......
Old May 11, 2004 | 08:05 PM
Ballinger's Avatar
Default Re: (Zerob16eg)
no there isnt anything on it it looks good must just be the little spring.. i'll give'er a shot tommorw...
thanks guys!
cclodfe
Jun 8, 2013 05:25 PM
GoSickemRobert
Oct 9, 2011 02:14 PM
SRZsmack
12
May 25, 2009 09:27 PM
96azure
Oct 5, 2006 10:50 AM
silver89civic
Mar 13, 2005 06:29 PM
