shifter sitting low...?
first of all, i already did a search. i always do. moving on...
my shifter has vertical play and i think it sits lower than it used to. this is causing it to occasionally rattle on my exhaust piping.
is the vertical play normal on a shifter? (i do have a DC short shifter btw, yea some of you think its crap i know but i don't remember this ever being a problem before. especially the rattling)
Should i get a new shift ball holder (don't know the name, u know, the white thingy that holds the ball of the shifter)? What do you guys think?
i have the same problem right now.
i have STR or SRT or whatever and it's adjustable so i can just raise it up a bit.
mine had minimal cleanrance but after i put TEin's i hit my head/pipe so it had no more clearance. so it started hitting..
i hate that sound. car sounds cheap
i dont know about your case tho.. try pulling the pipe down a bit or if you have stock b-pipe take the heatshield off.. that will give you some room.
good luck
.i dont know about your case tho.. try pulling the pipe down a bit or if you have stock b-pipe take the heatshield off.. that will give you some room.
good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 »</TD></TR><TR><TD CLASS="quote">i dont know about your case tho.. try pulling the pipe down a bit or if you have stock b-pipe take the heatshield off.. that will give you some room.</TD></TR></TABLE>
well i've checked my b-pipe and there's no way to make it hang any lower. I'm thinking if i change out my shifter ball holder it might hold the shifter higher...can anyone confirm this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jsk62 »</TD></TR><TR><TD CLASS="quote">
well i've checked my b-pipe and there's no way to make it hang any lower. I'm thinking if i change out my shifter ball holder it might hold the shifter higher...can anyone confirm this?</TD></TR></TABLE>
i dont know if the ball holder will make it higher...
i'd say go back to stock
b-series-em1
Apr 28, 2009 11:33 PM
Delano5050
10
Feb 25, 2008 03:27 PM
