Headgasket blown????
Old May 10, 2004 | 09:14 PM
4cefedcrx's Avatar
Default Headgasket blown????
my car sounds almost like a WRX at idle. It overheats if sitting at idle for awhile, but my fan works and its a new radiator. just need to know what you guys think about it being the headgasket. thanks alot
Old May 10, 2004 | 09:31 PM
SKDRCR's Avatar
Default Re: Headgasket blown???? (btlefedlude)
what does the oil look like, is it a milky brown color?
what about the coolant, does it look alright?
is there any smoke coming from the exhaust, what color?
have you ever changed your thermostat?
Old May 10, 2004 | 09:45 PM
PrecisionH23a's Avatar
Do a compression test and/or cylinder leakdown test. Both can be misleading but the 2nd one is more accurate.
Also, let the motor idle and remove the radiator cap. If you see TINY bubbles coming up then that is a pretty damn accurate indication your HG is gone. Also, pull your plugs and see if you find any white specs on them that have a tiny greenish hue on them.
Old May 10, 2004 | 09:46 PM
98TypeSH's Avatar
Default Re: Headgasket blown???? (PrecisionH23a)
usally when it sounds like a wrx (i had same prob) i had my #1 injector take a fat poop. replaced it, problem solved
gotta get new o-rings and seals, thats a given
Old May 10, 2004 | 11:38 PM
petrv's Avatar
Default Re: Headgasket blown???? (98TypeSH)
Check out this thread: https://honda-tech.com/zerothread?id=826259. I had also a blown head gasket.
mondies_8
Apr 6, 2012 06:43 PM
chaotic_effect
Honda Civic (2001 - 2005)
Nov 30, 2011 01:55 AM
Blanket Jackson
Apr 26, 2006 10:44 AM
achanjr
17
Nov 9, 2004 10:02 AM
intekragsr
Mar 27, 2003 11:23 AM
