custom brake lines
Old May 10, 2004 | 09:14 PM
B18C_eg's Avatar
Default custom brake lines
i want to run braided steel lines from the master cylinder to prop valve and from prop valve directly to calipers (front calipers atleast)
would i run into any problems at anytime with the pressure goin thru these lines?
would they be more prone to failure then hardlines?
ive seen a few poeple using braided line from master cylinder to prop valve, what kind of effect does this have on peddle feel?
same with the clutch, ive seen a few with braided lines that replace the whole hardline, what effect does this have on peddle feel?
thanks
Old May 10, 2004 | 09:52 PM
boostn420's Avatar
Default Re: custom brake lines (B18C_eg)
I did the clutch on my car and the difference was about the same as doing it to your breaks. It basically moved my engage point slightly.
I wouldnt do it to the other hardlines. Even braided lines can go bad over time and you wont see it til its too late. I done think that **** would loook cool either it would be a mess. The hardlines never move and are way less prone to fail. Those are the same brakes that stop you from killing yourself or other people I would leaves those lines alone.
Old May 11, 2004 | 02:47 AM
B18C_eg's Avatar
Default Re: custom brake lines (boostn420)
im not worried about how the braided lines would look....my prop valve is no longer mounted on my firewall, therefore i have to re-route the lines. i figured braided would be the easiest, and wanted to know if they would function properly also
what size line and fittings did u use for the clutch? and what thread are the fittings?
Old May 11, 2004 | 06:18 AM
Sliced Beard's Avatar
just get a tubing bender and run lines the proper way
Old May 11, 2004 | 06:27 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: custom brake lines (dirtyd463)
Actually I just saw stan from http://www.fast-turbo.com do a complete stainless steel line on a honda. Kinda cool. flamenco-t here on HT.
art
integrawow
Suspension & Brakes
Jun 15, 2010 01:27 AM
RockWolf
Nov 9, 2006 08:16 AM
wantboost
101
Dec 11, 2005 05:09 PM
Pandahatch
Mar 21, 2005 08:19 AM
menkio
Mar 13, 2005 11:40 AM
