Clutch pedal dead.
Old May 10, 2004 | 08:34 PM
Tomatohatch's Avatar
Default Clutch pedal dead.
so in the past few days, id get in my car and press the clutch in to start it, then release the pedal. but it wont pop up, i had to pump it a couple of times to get it to spring back up. pretty much anyime it sits for a period of time it does this. and seems to be getting worse.
what do you guys think it might be?
Clutch master cylinder?
worn out clutch line?
re-bleed the system?
Old May 10, 2004 | 08:44 PM
Built Beast's Avatar
Default Re: Clutch pedal dead. (delsol2nr)
probably needs fluid, have you check that first? then go from there...
Old May 10, 2004 | 08:50 PM
ieatrice's Avatar
u need to bleed ur clutch
Old May 10, 2004 | 08:54 PM
Kamin's Avatar
Default Re: Clutch pedal dead. (ieatrice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ieatrice &raquo;</TD></TR><TR><TD CLASS="quote">u need to bleed ur clutch</TD></TR></TABLE>
needs to check fluid first. if problem presists then bleed.
Old May 10, 2004 | 09:19 PM
ieatrice's Avatar
Default Re: Clutch pedal dead. (Kamin)
ditto.
jdmstyleg
11
Sep 27, 2009 06:16 PM
cleanej2
18
Feb 1, 2008 11:42 AM
Lb1atx
Sep 7, 2007 05:16 AM
crdcz03
May 5, 2005 06:43 PM
MacLeanQuinn
Feb 7, 2002 02:43 PM
