VSS problem.
Old May 10, 2004 | 07:30 PM
Moe's Avatar
Moe
Default VSS problem.
Every now and then wehn im driving around, my spedo gauge will just start jumping around and going nuts.
What could be causing this... i have yet to pull out the VSS unit to inspect it for any damnage or wear. Nor have i tested it to see if its getting the right voltage reading.
Just looking for other reason's outside of those two possiblitys that could cause this problem.
I am running a Exedy CM flywheel and Organic clutch also.
Old May 23, 2004 | 07:49 PM
jetpilot's Avatar
mine does the same thing, I swapped it with a friends vss and it went away. I get cel #17 from time to time so I guess its just broken so Ill have to buya new one. Are all of them the same (d series trannys)??
Old May 26, 2004 | 09:23 AM
Moe's Avatar
Moe
Default Re: (jetpilot)
Dunno i havent chekced any cel's i know i have at least one... i shoudl check tomorrow.
I just wanted to see if anyone was having any similar problems...
Old May 26, 2004 | 09:53 AM
unknown0001's Avatar
Default Re: (Moe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Moe &raquo;</TD></TR><TR><TD CLASS="quote">Dunno i havent chekced any cel's i know i have at least one... i shoudl check tomorrow.
I just wanted to see if anyone was having any similar problems...</TD></TR></TABLE>
I had this problem recently...went to junk yard got a VSS from automatic EG civic and put it in and now my speedo works
Old May 28, 2004 | 10:44 PM
Moe's Avatar
Moe
Default Re: (Mr.RHTuner)
Well it works... but sometimes. It will jsut start dancing, maybe i should just take the same approach as you.
And not worry about it anymore.
Old May 29, 2004 | 12:54 PM
justBLZE's Avatar
Chopper 2 Hopper
Default Re: (Moe)
Mine does the same thing, it came to the point that speedo doesn't work on cold morning for the first few minutes after startup.
I'm gonna need one soon.
Also I've heard D-series will work on B-series is that true?
Old May 30, 2004 | 04:52 PM
Shaun's Avatar
Default Re: (t0mmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0mmy &raquo;</TD></TR><TR><TD CLASS="quote">Also I've heard D-series will work on B-series is that true?</TD></TR></TABLE>
bump....anyone know?
EDIT: I did a search, and found out it will work
Modified by Shaun at 9:07 PM 5/30/2004
Old May 31, 2004 | 11:37 AM
Shaun's Avatar
Default Re: (Shaun)
I just switch my D series y7 VSS into my 99-00 Si tranny, it did not work...... are non vtec and vtec vss's diffrenet?? I notice the round part on the si was bigger
Old May 31, 2004 | 10:03 PM
justBLZE's Avatar
Chopper 2 Hopper
Default Re: (Shaun)
I'd really like to find out.. anyone?
Old Jun 1, 2004 | 04:56 PM
TwoPointZero's Avatar
Banned
Default Re: (tommy-)
Vtec and Non Vtec and D series and Automatic VSS's are all the same. The
d-series vss's have plastic gears opposed to b-series have aluminum gears
Old Jun 1, 2004 | 05:14 PM
jetpilot's Avatar
my 92 d16z6 vss has aluminum gears and it wont plug up to a friends 96 dx hatch. The plug wont go in completly but his works on mine
Old Jun 2, 2004 | 10:00 AM
Moe's Avatar
Moe
Off to http://www.hondaautomotiveparts.com to compare part numbers... brb with results.
part number for a OBD-2 96-00 ex is 18560 for the entire VSS. http://www.hondaautomotivepart...LEASE
part number for a 00si is 18570 or 18571 http://www.hondaautomotivepart...LEASE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Vtec and Non Vtec and D series and Automatic VSS's are all the same. </TD></TR></TABLE>
I dont see where the difference is other than price... if i new it would work for sure i would go out and get one right now.
Modified by Moe at 7:11 PM 6/2/2004
Modified by Moe at 7:26 PM 6/2/2004
Old Jun 2, 2004 | 01:28 PM
Shaun's Avatar
I was talking in regards to a non vtec D-series VSS on a Vtec b-series tranny, it did not work for me
Old Jun 3, 2004 | 09:02 PM
Kevedge's Avatar
Default Re: (Shaun)
It could just be a broken plug. I know thats the problem with my car. The plug is missing the little tooth that holds the plug on and when ever I go and get on my car it will sorta come loose and casue my speedo to jump. So just try going down and pushing down on it and making sure its in all the way. A temp. fix that I used was to put a zip tie over the plug and hold it down. I have yet to have any sort of problem!
michjdm
Feb 27, 2007 01:44 PM
Haleiwa-Brando
Oct 1, 2006 02:45 AM
Apocolipse269
19
Apr 7, 2006 12:07 AM
Airmax55555
Dec 29, 2003 01:35 AM
del_parker
May 7, 2003 05:07 AM
