Need help with y21 trans
Old May 10, 2004 | 06:19 PM
BLiMP's Avatar
Default Y21 Trans and Cam gear line up????
Hello I just bought a motor (b18c) gsr from a local guy. He bought it from hmotors and I saw the trans sticker. It is a y21. He said that the 2nd and 3rd gear synchros are bad, so i'm gonna rebuild it before i put the motor in my car. I need help figuring out what motor it came out of, so i know what parts to order. Thanks
Modified by BLiMP at 3:06 AM 5/12/2004
Old May 10, 2004 | 07:44 PM
BLiMP's Avatar
Default Re: Need help with y21 trans (BLiMP)
Also i was ripping the t-belt cover i noticed that the cam gear markers weren't in sync. When i turned to the crank to line up the marks in the middle, they didn't line up. They were lining up a little higher, not in the middle. Then the UP arrows on each cam gears weren't going together when i turned the crank. Can i get some feedback on this. Thanks
Old May 10, 2004 | 07:51 PM
BLiMP's Avatar
Here is a pic of the cam gears
The blue arrows are pointing to the UP arrows
The orange is pointing to the markers.
Old May 10, 2004 | 08:57 PM
Sliced Beard's Avatar
ummm did he try to drive it/ start it up like that
you may have a busted engine, i dunno for shure cuz i dont know if a gsr is an interference engine
first things first set the cams in the proper location before you do anything and make shure everything is at TDC before you try to start it
you may have gotten ripped, when you were spinning the engine did it seem hard to turn at some point and did you hear any grinding/contact noises /
Old May 10, 2004 | 08:58 PM
Default Re: Need help with y21 trans (dirtyd463)
also it looks like home boy has the intake cam in the exhaust cam location and vise versa
switch the cams
the up arrows should be at TDC and the two dashes/dots should be on the inside
Old May 11, 2004 | 06:11 PM
BLiMP's Avatar
Hmmm. Is there anyone else i can get some feedback from. You sure about the switched cams?? I was thinking why would he have it like that(previous owner)??? Well ya the only way to figure it out is to take the head off, but i would like to get some other peoples advice before i do anything else. Thanks.
Old May 11, 2004 | 06:28 PM
gamakichi77's Avatar
Y21 is tranny from civic year 92, hydro with 4.4 final drive.
also has in cable types from Integra
Old May 11, 2004 | 06:30 PM
BLiMP's Avatar
Default Re: (acidburns_di)
Ya i called up honda about that trans. Its out of a 94-95 delsol vtec. THanks. Now i'm stuck on this cam gear deal. AHHH
Old May 11, 2004 | 06:57 PM
BLiMP's Avatar
Default Re: (BLiMP)
Hmm started turning the crank again. It sounds like the air is just going past the rings and coming out the bottom. I don't think any air was coming out of the exhaust.
Man i'm really getting frustrated. I don't have some tools right now to take off the head, but i'm really scared to also. If anyone else think they can help me out that would be the BEST. Thanks
Modified by BLiMP at 12:25 PM 5/12/2004
obuhmyuh
Jun 8, 2008 09:38 AM
sleeperb16a
Sep 24, 2007 08:12 AM
sabertooth
Jun 18, 2004 08:53 PM
coldfiremx
Mar 3, 2003 04:57 AM
