93 z6 vtec solenoid problem
well i finally got around to rewiring the vtec spool valve and pressure switches with some DIY work (perfect fit terminals, soldering, and heat shrink wrap) that had been causing me to throw CELs 21 and 22. now after clearing my ECU of the codes im still throwing 22 for the pressure switch.. which just happens to be the one place i was a little confused on. on my car it is a 2 wire plug with one black and one blue/black. in my haynes manual (only thing i had on hand), it shows the wiring diagram as having the blue/blk wire on the left terminal and the blk on the right (looking at the engine from dizzy side). i realize not asking here first couldve cost me some time but i really wanted to get this problem fixed... does it sound like my problem is involved in reversing these wires or should i look elsewhere?
also.. if the vtec has not been wired up in this car for some time, could i also be looking at replacing a frozen solenoid assembly?
thanks in advance
thanks in advance
when you say that are you referring to the male plug that is supposed to be there, b/c i sort of made my own since the only way i could get a replacement around here was to buy the whole wiring harness... so i have no frame of reference as to which terminal in the female connector goes to which wire.
thx tho ill take a look and see if it makes any more sense
The black wire gets grounded to the thermostat where all the other wires ground also. The blue/black wire runs to the plug at the shock tower harness.You can just solder a few feet of wire to the blu/blk one and heat shrink it instead of trying to track down the connector. See thread below.... https://honda-tech.com/zerothread?id=846090
i know where it goes on the tower harness.. thats all still connected. my problem lies in which terminal on the pressure switch on the solenoid itself goes to which wire since i dont have the plug that goes there. ill give moto27cm's advice a try tomorrow when i have some light to work with but if anyone else can tell me right now whether the blu/blk wire goes on the LEFT terminal or not thatd help solve my problem on the spot.
thx for all the help and that thread is still very useful as far as checking things from the tower harness back to the ECU
RicedREX
Jul 13, 2004 01:23 PM
im a monster hehe
Dec 24, 2003 11:12 PM
Sketch_hs
Dec 19, 2003 08:16 AM
