can itr front lca's fit on an eg with a gsr sway bar?
just like the title says. i wanna put on my gsr sway that i have but i don't have holes on the lca's. will the itr ones fit on my car (92 dx hatch) and on a 2000 gsr sway bar?
thx
thx
Im sure they will. Right now I have a set of front lca's and sway bar from a gsr that im gonna put on my 92 hatch when I do my brake swap.
You also have to make sure that you have item 8/9 because the sway bar mount uses that stud you see sticking out of the bottom of it.
you can see the line coming from it.
Modified by _BEN_ at 11:45 AM 5/11/2004
even the stock civic lca bushing housing / pivot has the stud even tho it does not have a sway bar
the thiing you have to worry about is if the front LCA has a bolt hole location for hte swaybar to go
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox »</TD></TR><TR><TD CLASS="quote">i haven't checked if my control arms have the wholes drilled for it, but i've heard that the 92 ' dx ones don't have them.</TD></TR></TABLE>
I have the GSR Front LCA's on my EG Hb... went on with out any problems.
the pic shows the part that the civic does not have
LHC
Sep 3, 2003 04:01 AM
mamaboy
Oct 29, 2001 10:30 AM
