s2k rims on eg hatch??
Old May 10, 2004 | 05:07 PM
sohcvtec66
Guest
Posts: n/a
Default s2k rims on eg hatch??
will it work on a eg hatch? has anone seen it been done? curious
pics r cool
Old May 10, 2004 | 05:09 PM
aznboysrfr's Avatar
('04) offset is +60 ... it won't work unless you get extended studs and wheel spacers
same goes with the new itr/ctr rims
Old May 10, 2004 | 05:28 PM
lowgman's Avatar
Default Re: s2k rims on eg hatch?? (sohcvtec66)
The bolt patterns aren't even the same!
Civic = 4 x 100
S2000 = 5 x 114.3
Unless you got some sort of conversion
Old May 10, 2004 | 05:39 PM
ek_david's Avatar
https://honda-tech.com/zerothread?id=197147
Old May 10, 2004 | 05:40 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: (b20vtec17)
it will work if you do a 5 lug conversion. S2k wheels are the same bolt pattern as ITR wheels.
Old May 10, 2004 | 06:20 PM
Pat McGroin's Avatar
Default Re: (AzntaggeR)
J.Fuggi if i remember had them on his civic. He had the 5 lug conversion and got four front wheels. From what I have read you can not use the rear wheels.
Old May 10, 2004 | 06:22 PM
ej1 pilot's Avatar
ive seen it done, looks good, id show pics but im not on my own computer right now
Old May 10, 2004 | 06:24 PM
Eg Smurf's Avatar
Soething like that is great, but if you have a set up like that I hope you have a legit reciept for it.
Old May 10, 2004 | 06:34 PM
Mar_DC2's Avatar
Default Re: s2k rims on eg hatch?? (l0utkastl)
IMO it looks ugly as hell. they're way too skinny for their diameter, and it just makes the whole car look odd.
Old May 10, 2004 | 06:40 PM
The G2 Racer's Avatar
You need a 5lug suspension for the bolt pattern to be the same.
Then you need 4 front wheels.
Old May 11, 2004 | 02:02 PM
b18c1delsol's Avatar
can't be done, Why would you want to?
Old May 11, 2004 | 02:07 PM
ninety9ex's Avatar
Default Re: s2k rims on eg hatch?? (b18c1delsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c1delsol &raquo;</TD></TR><TR><TD CLASS="quote">can't be done, Why would you want to?
Dude they are both Honda's... I dont think this ever aplies to two different hondas swapping parts as long as the person want to do it has the bankroll to do it... Just my $0.02
Old May 11, 2004 | 02:08 PM
jolt-tsp's Avatar
You can do it on a 5 lug conversion. You would want to use either all fronts since the s2k has different widths for the front and back. The offsets aren't really right for a civic though and would require some modification or spacing. Not really worth it, but thats just my opinion.
Old May 11, 2004 | 02:28 PM
ej1 pilot's Avatar
please dont post things you dont know
Old May 11, 2004 | 02:31 PM
Phil DeVtec's Avatar
negative...it HAS been done!
Old May 11, 2004 | 02:35 PM
Mr Hammond's Avatar
a/k/a Jomo
Ok we've established it can be done.
As was stated you need a 5-lug conversion done and then you would need to purchase 4 front wheels.
You can either use the S2000 front wheels, OR NSX wheels work well and look considerbly nicer.
I have seen both on an ITR and both look fine without any spacers at all.
SEARCH!!!
Old May 11, 2004 | 03:12 PM
kingSfit's Avatar
5 lug
Old May 11, 2004 | 05:08 PM
sohcvtec66
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtec17 &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=197147</TD></TR></TABLE>
hey thanks alot man, that looks sweet, - then 00 si lip
Old May 12, 2004 | 12:33 PM
ek_david's Avatar
no prob
Old May 12, 2004 | 12:55 PM
OEMedUP's Avatar
yah it can be done, and i want the s2's rims bad. they are clean as hell
The_Head
Jun 12, 2005 09:51 AM
AlienKrOZ
Jul 8, 2004 11:19 AM
CostcoVTEC
Nov 15, 2003 03:35 PM
SubieDude
May 28, 2002 03:07 AM
uc0083
Apr 27, 2002 07:10 PM
