car driving weird
Old May 10, 2004 | 04:39 PM
burningwrek's Avatar
Default car driving weird
i just installed a skunk2 intake mani on my 98 civic ex. when i hit the gas at low rpms in a higher gear, or just at low rpms, the car kinda stutters but drives fine in midrange and topend. any ideas guys? thanks
Old May 10, 2004 | 04:48 PM
AWDxBOOST's Avatar
Default Re: car driving weird (burningwrek)
probably just cause ur in low rpms....lol
if its from the new mani, check the seal to the block and **** like that....how does it idle?
Old May 11, 2004 | 05:41 AM
Default Re: car driving weird (itr_eg)
well my dad said the same thing about being in low rpm and ive been driving my car for over 3 years so i can tell when somethin weird is going on. its NOT because I'm in low rpm. it wasnt doing this before. the weird thing is that after i installed the IM it was fine, and i drove it that way for 2 weeks. yesterday i jacked up my car, changed the shocks and installed my rear camber kit and after I lowered it down and drove it, it starts doing this crap. i did reuse my gasket which i know im not supposed to, but i couldn't drive to go get a new one. if the gasket is leakin, do you think that could cause my car to stutter when i accelerate from low rpms?
well if i start it up cold, it revs to 1.5 then drops to around 750. if its warm, i just revs to 750 and holds.
Old May 11, 2004 | 05:52 AM
JimmyAtlantis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by burningwrek &raquo;</TD></TR><TR><TD CLASS="quote">well if i start it up cold, it revs to 1.5 then drops to around 750. if its warm, i just revs to 750 and holds. </TD></TR></TABLE>
That sounds dead on. From what I understand the Skunk2 IM isn't real good for low end torque, but excellent in mid to high range.
Old May 11, 2004 | 05:54 AM
Default Re: car driving weird (JRI94)
yea, low end has lost power but uphigh its gotten alot better. but it never stuttered before like this when i pressed the gas.
Old May 11, 2004 | 07:28 AM
bumpin for the mornin
Old May 11, 2004 | 03:02 PM
the problem is almost like im giving it gas and its stuttering for a second, like the injectors are pulsating or something. thats the only thing i can compare it to. im not sayin thats it, but its hard to explain without actually driving it. some help would be greatly appreciated.
Old May 11, 2004 | 04:23 PM
gimme feedback
Old May 11, 2004 | 04:27 PM
just a bit of info: i cracked the plastic housing around the knock sensor when removing it. the sensor inside seemed to be undamaged, but if it was damaged how would that affect performance of my vehicle? thanks guys
Old May 11, 2004 | 04:36 PM
WhiteEG6's Avatar
Have you checked your ignition system? Plugs,wires,cap and rotor? That would be the first place I would start. If you need help PM me. I live in Jax, not too far from you.
Old May 11, 2004 | 04:40 PM
Default Re: (WhiteEG6)
why would that have something to do to it? i didnt even mess with that stuff, just changed out the IM and it does this mess.
Old May 11, 2004 | 04:47 PM
WhiteEG6's Avatar
You never know what could go wrong. I once changed my oil and for some f#*king reason my timing was off. If its sputtering its either fuel or ignition.
Old May 19, 2004 | 05:31 PM
well i figured out what the deal is. the spark plug wires are popping loose from the valve cover, just rising a tad bit off the back of the plug. i can push them down real good, drive it perfectly for a while, but they pop back up, i guess from vibrations. any idea on how to keep them stuck down?
Old May 19, 2004 | 05:39 PM
SolObsession's Avatar
Stick them down with some JB Weld, that stuff works for anything.
On a serious note, buy new plugs and wires. If you can afford a I/M then you should be able to get the plugs and wires. Maybe they are a little dry rot or just old and they wont stick on right. Good Luck.
Old May 19, 2004 | 05:45 PM
Default Re: (SolObsession)
well as far as i know, theyre the ones that came from the factory. havent changed em since i got the car a couple years ago, so theyre probably due for a change.
yea, i can afford the 70 bucks or so for the MSD spark plug wires. <U>anyone want to suggest some good plug wires to go with? </U>
Old May 19, 2004 | 06:26 PM
Default Re: (burningwrek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by burningwrek &raquo;</TD></TR><TR><TD CLASS="quote">yea, i can afford the 70 bucks or so for the MSD spark plug wires. <U>anyone want to suggest some good plug wires to go with? </U></TD></TR></TABLE>
You said MSD wires adn then to suggest wires?
Do a search, I remeber seeing a post about how MSD, etc weren't any better for 99% of Hondas. OEM has a high spark capability or something like that. But I would search.
Old May 19, 2004 | 07:34 PM
Jaydeep's Avatar
When do you guys change your plug wires. How many miles.
Old May 20, 2004 | 03:21 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by burningwrek &raquo;</TD></TR><TR><TD CLASS="quote"><U>anyone want to suggest some good plug wires to go with? </U></TD></TR></TABLE>
Hmmm...how about OEM.
Old May 20, 2004 | 12:15 PM
Default Re: (JRI94)
yea i just got the ones from discount auto
killaberna
Jul 8, 2013 10:44 AM
949
15
Oct 14, 2009 11:26 AM
`chrisb
Feb 26, 2008 03:33 PM
ls95hatch
Jun 9, 2003 07:21 AM
TheIntegraGuy
May 6, 2003 03:57 PM
