after 3 hours of trying to make it work..... it didnt fit
Old May 10, 2004 | 03:14 PM
illdstu's Avatar
Default after 3 hours of trying to make it work..... it didnt fit
hey guys i got a 97 civic coupe and i bought a suspention tech sway bar off a guy with a ek style hatch, it came with his car but not installed so he thought it was for a ek civic so i bought it for 100 bucks(this thing is mint) sway bar end links bushings all that stuff new hard ware....... so i get it on my buddys fathers lift i start taking everything apart that is needed, i knew that the spring bolts on the header were going to snap so i saved the hassel and bought new ones b4 i even started this...waist of my money they didnt break. but one of the sway bar bracket bolts snapped so i had to drill them out took about 45 mins and 4 bits. i get everything up and ready to go, i just had to bolt up the 2 sway bar brackets i got one side and i noticed the bar rubbing hard in 2 spots b4 i even got the other bracket on so i figured it was just cause the wheels were hanging and once i put the car back down it would pivot the sway bar so there would be no rub but nope not with my luck... so i took it back out and put my stock sway bar back on and i got home and looked up the part #'s and sure enought it was for a eg so if anyone would be intrested in a 1 inch in diameter front bar for a 92-95 eg 100 bucks this bar is brand newww thanks guys or anyone willing to trade suspention componets for a ek civic thanks
tim
Old May 10, 2004 | 03:16 PM
dantastic's Avatar
Default Re: after 3 hours of trying to make it work..... it didnt fit (illdstu)
wow. pretty tough to read. anyways, are the bars for EG's with or w/o swaybars?
Old May 10, 2004 | 03:20 PM
illdstu's Avatar
well. when i got the bar it had these funny looken block things that the endlinks bolted to. i am assuming this bar is up grade to a eg with a sway bar allready equipt.. i will post pictures if intrested
dsl77
Aug 24, 2016 02:05 PM
exist12
Nov 29, 2009 10:52 PM
kulo
Suspension & Brakes
20
Jan 25, 2009 10:02 PM
b18LS
Suspension & Brakes
Oct 10, 2007 05:16 PM
{Powered by VIII}
Jul 19, 2004 05:50 PM
