VAFC question!!
Old May 10, 2004 | 01:24 PM
B00ST2nR's Avatar
Default VAFC question!!
I went in for a smog test today. I passed the Function Check and Emissions Test, but failed in the Visual Inspection.
I have to fix 2 things. A Fuel leak in the Fuel Rail, and the VAFC.
I ordered a new fuel rail, so that should be comming soon. The problem is the VAFC.
Now my question is... if I unplug the VAFC from my ECU, will it save the settings it has right now? Or will it go back to the initial settings??
Old May 10, 2004 | 02:10 PM
92b16vx's Avatar
They save settings till intialized I believe.
Old May 10, 2004 | 08:45 PM
B00ST2nR's Avatar
Default Re: (92b16vx)
anyone else? Someone told me once you unplug the VAFC it goes back to initial settings.
Someone know FOR SURE?
Old May 10, 2004 | 08:51 PM
92b16vx's Avatar
Default Re: (Skunk2nR)
I was reading a post here, and the person was asking about the previous owners settings, and how they were still in the unit, and if it would be safe to run them. But I don't recall if the unit is hooked up to a constant power for memory (I think it is a key on 12v, and my manual is...somewhere) I would say it it stores them even when disconnected.
Old May 10, 2004 | 08:57 PM
ILuvJDMITR's Avatar
Default Re: VAFC question!! (Skunk2nR)
cant you just uninstall it partially and hide it under the dash for a day? or will they look there as well?
Old May 11, 2004 | 09:44 AM
2kgs-R's Avatar
Default Re: VAFC question!! (ILuvJDMITR)
I have a vafc and have disconneted it many times, the settings don't get deleted the vafc keeps the settings stored. However if you just disconnect your vafc then your car wont run right unless your using a harness and just remove the harness.
Old May 11, 2004 | 11:16 AM
B00ST2nR's Avatar
Default Re: VAFC question!! (2kgs-R)
you mean the harness clip in the middle?
I'm gonna goto the smog shop and unclip the VAFC from the middle harness RIGHT before the smog test. I hope that will work.
Old May 11, 2004 | 04:26 PM
RedZone's Avatar
you cant just unplug it and go, you have to disconect the vacf harness fron the ecu and put it back to stock. THe VAFC will keep your settings forever unless you reset it in the menu with it powered up so dont worry about losing your settings.
Old May 14, 2004 | 09:37 AM
2kgs-R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skunk2nR &raquo;</TD></TR><TR><TD CLASS="quote">you mean the harness clip in the middle?
I'm gonna goto the smog shop and unclip the VAFC from the middle harness RIGHT before the smog test. I hope that will work.</TD></TR></TABLE>
no not the harness clip in the middle, I meant an aftermarket harness which is used to install a vafc without soldering anything. The Middle clip thats used to extend the vafc wiring can't just be disconnect, if it is your car wont operate correctly. If you want to take the vafc out of your car you have to unistall it, meaning you have to unsolder and resolder all the connections if you don't have one of those aftermarket harnesses.
Old May 14, 2004 | 09:41 AM
EJ1 wilcox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2kgs-R &raquo;</TD></TR><TR><TD CLASS="quote">
no not the harness clip in the middle, I meant an aftermarket harness which is used to install a vafc without soldering anything. The Middle clip thats used to extend the vafc wiring can't just be disconnect, if it is your car wont operate correctly. If you want to take the vafc out of your car you have to unistall it, meaning you have to unsolder and resolder all the connections if you don't have one of those aftermarket harnesses.</TD></TR></TABLE>
Yes, what he said.
You can't just unhook the VAFC from the harness and expect your car to run properly.
You MUST uninstall the VAFC completely, ie. unsolder and resolder.
IMO it would be too much of a pain to do that, just hide it under your dash somewhere. It shouldn't be too hard to hide depending on where you have it mounted.
Old May 14, 2004 | 03:04 PM
B00ST2nR's Avatar
Default Re: VAFC question!! (koreanwilcox)
oh ok.
I went ahead and hid it under the dash along with all the wiring under the carpet. I hope he doesn't check the ECU and dig under the carpet to find any wiring.
Old May 14, 2004 | 09:20 PM
2kgs-R's Avatar
Just as long as your not going to a state ref. you I don't believe you have anything to worry about the smogger guy looking at your ecu or wirings going to it.
OT though are you going to get your smog done with your stock cat. or do you have an aftermarket one?
Old May 14, 2004 | 10:51 PM
B00ST2nR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2kgs-R &raquo;</TD></TR><TR><TD CLASS="quote">OT though are you going to get your smog done with your stock cat. or do you have an aftermarket one?</TD></TR></TABLE>
Stock cat for smog.
Old May 15, 2004 | 06:11 PM
cajnatc's Avatar
The settings will be saved. I unplugged mine a few times and never lost my settings
1GPlusSH
Jan 27, 2007 11:49 AM
1999all_motoR_teg
13
Jan 12, 2005 09:53 AM
bpowa
10
Oct 26, 2004 11:09 PM
B00ST2nR
May 10, 2004 10:09 PM
max
Oct 14, 2001 02:54 PM
