Short shifter how to?
Old May 10, 2004 | 10:03 AM
Mrfeee1's Avatar
Default Short shifter how to?
I hope everyone doesn't me. But i wanna know if there is DIY out there for installing a short shifter. I tried searching but couldn't come up with anything. I was kinda shocked.
Old May 10, 2004 | 10:10 AM
ej1 pilot's Avatar
Default Re: Short shifter how to? (Mrfeee1)
theres is multiple threads on it...search harder
Old May 10, 2004 | 10:17 AM
kKdARIAN's Avatar
Vice President/CEO
Default Re: Short shifter how to? (CXinthemaking)
yea dood.. just search for "short shifter install"
be sure to click search archived threads..
http://www.overboost.com/story.asp?id=360
there is a link that may help
Old May 10, 2004 | 10:54 AM
jolt-tsp's Avatar
Default Re: Short shifter how to? (kKdARIAN)
once you get under the car, it's pretty easy to figure out
Old May 10, 2004 | 11:03 AM
SOHC_MShue's Avatar
someone didn't search very hard
Old May 10, 2004 | 12:47 PM
BigZ88's Avatar
Default Re: Short shifter how to? (SOHC_MShue)
eh, i'm pretty bored, so i'll try to help the best i can from memory.
from inside the car, take off the stock shift ****, and remove the console around the shifter.
jack up the car high enough to get your body under the center part of the car.
while under there, make it easy on yourself and drop the exhaust down out of a few of the hangers to get it out of the way.
Now, look up and see where the shifter goes through the floor of the car. I believe there are 2 12mm bolts that hold it into the car. Remove these bolts to drop the shifter down.
There should now be an assembly with a rubber boot, and 2 more bolts that hold the shifter to the linkages. Remove these and also remove the bolt going through the shifter.
Basically what i'm saying is this: This is a very very basic install, and if you take your time and just look at the situation, you will figure it out no problem. Remember not to tighten the bolt that goes through the shifter too hard or it may not move very freely....Any other questions just ask or PM me
07FG2
Honda Civic (2006 - 2015)
17
Jan 27, 2010 05:11 PM
sleepingciv
Sep 16, 2008 09:35 AM
islanderz13
Jun 9, 2008 10:23 AM
vietherbs
Apr 19, 2007 10:32 PM
JDMJunior
Jan 29, 2006 10:50 AM
