Tuner Style Nuts with Extended Wheel Studs
Old May 10, 2004 | 09:41 AM
HotRodEG6's Avatar
Default Tuner Style Nuts with Extended Wheel Studs
Hi,
I'm posting this here as I figure only the drag racing guys will have this problem.
My car is a street/strip car and my new Motegi DP6 Wheels require a tuner style nut. Here is the problem. I have ARP extended wheel studs on my Drivehshaft Shop hubs and I want to keep them.
What tuner style nuts do you use? I don't want to have to remove my extended wheel studs just to install me new wheels.
Thanks!
Old May 10, 2004 | 09:44 AM
Boostfed's Avatar
New User
Default Re: Tuner Style Nuts with Extended Wheel Studs (TurboMiata.net)
Maybe Skunk2?
Old May 10, 2004 | 09:54 AM
badCRX's Avatar
New User
Default Re: Tuner Style Nuts with Extended Wheel Studs (Boostfed)
possibly the Muteki open ended ones.
Old May 10, 2004 | 10:08 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: Tuner Style Nuts with Extended Wheel Studs (badCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by badCRX &raquo;</TD></TR><TR><TD CLASS="quote">possibly the Muteki open ended ones.</TD></TR></TABLE>
probably
Old May 10, 2004 | 01:14 PM
Kwuaymaikrup's Avatar
Thats what I run....
Old May 10, 2004 | 01:18 PM
ComposiMo's Avatar
If you get those 'Gorilla' locks that Discount Tire distributes, the end cap on it is really really thin, and can be ground off easily so that the stud can go all the way through it... then just run a tap through it, to clean up the threads on the bottom, and it would work fine. ... and the key is long enough that it'll accept the long stud and still be able to loosen and tighten the locks.
Of course it may not be worth it to do all of that, but i've used those Gorilla locks forever, and never had any problems with them (unlike someo ther brands out there), so its worth it to me for the peace of mind i guess...
Old May 10, 2004 | 01:22 PM
VisualAutoMotoring's Avatar
Default Re: Tuner Style Nuts with Extended Wheel Studs (ComposiMo)
you can use any open end lug nut...Muteki,Kyokugen....anything that's open end
Old May 10, 2004 | 03:44 PM
ebp 99 si's Avatar
Default Re: Tuner Style Nuts with Extended Wheel Studs (PRojectSi2)
i use kyokugen lug nuts on my car with my extended studs
they work fine for me
Old May 10, 2004 | 04:39 PM
N2O's Avatar
N2O
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ComposiMo &raquo;</TD></TR><TR><TD CLASS="quote">If you get those 'Gorilla' locks that Discount Tire distributes, the end cap on it is really really thin, and can be ground off easily so that the stud can go all the way through it... then just run a tap through it, to clean up the threads on the bottom, and it would work fine. ... and the key is long enough that it'll accept the long stud and still be able to loosen and tighten the locks. </TD></TR></TABLE>
We did the same thing and it worked out just fine.
Old May 11, 2004 | 07:17 AM
Rtype16's Avatar
Default Re: Tuner Style Nuts with Extended Wheel Studs (N2O)
Use your same lug nuts, but cut off the top of them.
Old May 11, 2004 | 07:35 AM
HotRodEG6's Avatar
Default Re: Tuner Style Nuts with Extended Wheel Studs (Rtype16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rtype16 &raquo;</TD></TR><TR><TD CLASS="quote">Use your same lug nuts, but cut off the top of them.</TD></TR></TABLE>
Can't, I currently use allen key style nuts and they won't work with extended wheel studs.
Think I'm going to get the Muteki lugs. I 've heard the tool is long enough to still work with ARPs from DSS.
Old May 11, 2004 | 08:00 AM
Rtype16's Avatar
Oh sorry I thought the picture was what you have.
Old May 11, 2004 | 08:59 AM
n-boost's Avatar
mark,
It's Ben, I had this issue too, on my Racing Hart cp-035's with the extended wheel studs in the front, Wheels Direct has the right open end lugs for this application, just take a existing lug to them and they can match up the right one,they are not too expensive at all. If you have any other questions give me a call on my cell....
Old May 11, 2004 | 09:14 AM
Jokerluv's Avatar
http://www.nutz4u.net/freesamples.html
Old May 11, 2004 | 10:26 AM
HotRodEG6's Avatar
I ordered a set of Muteki Open ended wheel nuts in silver from Evasive Motorsports. Should have them in around a week or so.
They have a H-T special for $32 shipping in USA and $42 shipped to Canada.
Old May 11, 2004 | 10:32 AM
96dc2's Avatar
Default Re: (TurboMiata.net)
McGard SplineDrive's are made for those type of wheels.
incredteg3
Sep 3, 2007 05:08 AM
SoCal EJ1
Apr 7, 2007 07:08 AM
mikeunreal2
Apr 16, 2006 02:55 AM
gakkuken
21
Jan 10, 2005 02:28 PM
zRd#1
May 14, 2003 11:46 PM
