how much power am i losing using my origanal d16 ecu w/ b16 swap?
Old May 9, 2004 | 07:43 PM
98k20ex's Avatar
Default how much power am i losing using my origanal d16 ecu w/ b16 swap?
i put a b16 in my 98 civic ex and am wondering how much power is there to be realized once i get the b16 ecu in that came with the motor? is that the best way to go as far as ecu's?
Old May 9, 2004 | 08:17 PM
Eg6LazyPt's Avatar
Default Re: how much power am i losing using my origanal d16 ecu w/ b16 swap? (98b16ex)
What are you doing running the d series ecu if you have the b series ecu with you?
The D16 ecu is set up for the D motor. Once you change it all the settings that are supposed to be correctly implied on the B motor will let you know what you are missing.
Old May 9, 2004 | 08:31 PM
b16ahybrid's Avatar
Default Re: how much power am i losing using my origanal d16 ecu w/ b16 swap? (Eg6LazyPt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eg6LazyPt &raquo;</TD></TR><TR><TD CLASS="quote">What are you doing running the d series ecu if you have the b series ecu with you?
The D16 ecu is set up for the D motor. Once you change it all the settings that are supposed to be correctly implied on the B motor will let you know what you are missing. </TD></TR></TABLE>
What are you trying to say?
He doesn't have a b16 ecu Yet, he wants to know if he'll realize any power gains from using the proper ecu.
Anyways it's not going to be that big of a difference, the ecu your using now is programed for the d16 engine, get the b16 ecu and it's got the dohc fuel and ignition curve. I would just chip your ecu with the dohc specs
Old May 9, 2004 | 08:45 PM
HATCHingMN's Avatar
Default Re: how much power am i losing using my origanal d16 ecu w/ b16 swap? (b16ahybrid)
chip that d16 ecu bro
Old May 9, 2004 | 08:50 PM
743power's Avatar
Default Re: how much power am i losing using my origanal d16 ecu w/ b16 swap? (HATCHingMN)
You're probably missing out on 25-40 whp with that ecu. Plus, your motor is probably running dangerously lean.
Also, you can't chip it since it's OBD2. You can try to find an OBD2a p30 from a usdm del sol, but they are rare and expensive. You can use a P2T from a 99-00 SI, but you will need a conversion harness, and they are expensive. Your other OBD2 options are to find a jdm ecu or you can use a gsr P72 ecu, but it won't be optimal for the B16. Your best bet is to run an OBD1 computer, like a chipped p28 and buy a cheap $75 or so OBD2a - OBD1 jumper harness.
Users on h-t you can PM to buy a chipped p28 from:
egajk (http://www.hyperducktuning.com)
Katman (http://www.jhpusa.com)
Kenji
IH8RICERZ [IMG][/IMG]
Old May 9, 2004 | 08:55 PM
IWearMyKswiss's Avatar
New User
fuel starvation like whoa
Old May 9, 2004 | 09:13 PM
RyanEJ8's Avatar
Default Re: (2.0 EK)
and lower revlimit.
Old May 9, 2004 | 09:23 PM
743power's Avatar
Default Re: (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">and lower revlimit.</TD></TR></TABLE>
good point, cutting a b16 off at 7 has got to suck.
Old May 9, 2004 | 11:07 PM
anothersickhatch's Avatar
Default Re: (x743x)
i know that when i had my old integra LS p75 on my b16 it was ****. i bought a jun chipped p28 and i noticed a world of difference. aT LEAST 15-20 horsepower with that computer.
you are losing a good amount of power with that computer.
jdmbeegee
Southeast (Sales)
Aug 8, 2008 07:11 AM
Stray
15
Jul 28, 2007 02:34 PM
crx90rcr
20
Aug 4, 2005 09:14 PM
DC2tuner
Jan 4, 2005 04:34 PM
