water leak
Old May 9, 2004 | 04:57 PM
surephase's Avatar
Default water leak
I just bought a 94' Accord and do not know what I am looking at. On the driver's side in the back of the engine I have a slow water leak. Is this the water pump or something else? I am having to keep refilling the radiator because or the water loss. If someone could help me I would appreciate it. Thank you.
Old May 9, 2004 | 07:45 PM
Mike813's Avatar
Default Re: water leak (surephase)
the radiator fluid is called "coolant" (green stuff)... if its leaking it could be a hose cracking, or maybe a hose is just loose or not clamped in right... you have to pinpoint the spot before someone can actually help you out. if you have a digital camera snap a pic of the part if you dont know what its called.
Old May 10, 2004 | 01:27 AM
surephase's Avatar
Default Re: water leak (Mike813)
I don't think that it is a hose. It is behind the engine block on the driver side of the car. I guess my question is: Where is the water pump? What does it look like? Is it near the timing belt housing? First of all, the leak is behind the block and up high. I have had it over heat on me and I don't know if the block is cracked or a part attached to it is leaking.
Old May 10, 2004 | 05:44 AM
Mike813's Avatar
well the waterpump is yes right next to the timing belt behind the cover. but its not a easy task to replace if you dont have a manual or experience.
Yao Saechao
Mar 26, 2018 01:25 AM
SPOOLINmatt
Mar 12, 2011 11:57 AM
jadziasman
Mar 24, 2007 07:39 AM
sslude
Feb 27, 2003 05:31 PM
