Integra or ZC ECU?
Old Nov 5, 2001 | 08:17 AM
Hondasaurs's Avatar
Default Integra or ZC ECU?
I recently did a ZC swap. I want to know what ECU is better to have. I did some research and discovered that the ZC has a 7200 rpm redline. One of the major reasons that ZC's blow up is because many people confuse the Integra computers 7800rpm fuel cut off as a red line. Also I have heard of the problems of ZC's with integra computers running to rich. I'd appreciate any input on this topic.
Old Nov 5, 2001 | 08:23 AM
TurboSedan's Avatar
New User
Default Re: Integra or ZC ECU? (ZC_CRX)
The ECU you want is the P28 92-95 EX/Si ECU.
Old Nov 5, 2001 | 08:43 AM
eg6ajk's Avatar
Default Re: Integra or ZC ECU? (97CivicFerio)
i don't think so: p28 is a obdI ecu for sohc vtecs...
for 88-91 civics with d16a6 or zc or even LS, you can run a PM7 ZC, PG7 (88-9 integra), Pm6 Si (90-1 higher rev limit), and Pr5 from JDM teg zxi or pr4 from 90-1 teg rs/gs/ls
by far the PG7 is best on ZC, and cheaper then ZC ecu ....
Old Nov 5, 2001 | 09:45 AM
TurboSedan's Avatar
New User
Default Re: Integra or ZC ECU? (eg6ajk)
Oops, my bad.
Old Nov 5, 2001 | 01:16 PM
Civhatch97's Avatar
I had the 89 ls ecu for my zc and never had any problems with it and i also shot a 65 shot on everyday and still never had any problems with the motor. You can get a ls ecu from the junkyard for about $75 or less.
stock_cx
Dec 31, 2003 10:26 AM
Toptul_Honda
36
Dec 26, 2003 08:38 AM
cr-x si
Aug 6, 2002 04:03 AM
jdm_ef9
Feb 2, 2002 03:20 PM
Hondasaurs
Nov 5, 2001 04:35 PM
