Opinions Needed!!
Old Nov 5, 2001 | 08:17 AM
destroyer101's Avatar
Default Opinions Needed!!
Hi guys,
I'm about to get a new used car for myself. I'm a NEWBIE here and would like to get some opinions from you guys. I'm looking at a 92' Honda Prelude Si. It's an automatic and has everything, i.e power door lock, power sunroof, etc. But the problem is the car has 130,000 miles. How reliable a Prelude is? Is there a lot of problem with 92' Prelude?? My main concern is the transmission and engine.
Thanks for any input.
Old Nov 5, 2001 | 08:21 AM
Apocalypse's Avatar
Default Re: Opinions Needed!! (destroyer101)
I'd be concerned cause' the transmission is an automatic.... ewww.
Old Nov 5, 2001 | 11:03 AM
Default Re: Opinions Needed!! (SpeedFreek24)
By the way, how could one tell if it's a Si model or S model?
Old Nov 5, 2001 | 12:04 PM
laughinxxx's Avatar
New User
Doesn't the S have a SOHC engine? I wouldn't buy the automatic unless you plan on swapping it out to a five speed. The engine should be good, but I'd check things like the timing belt, water pump, cv boots, interior lights, exterior lights, etc. Alot of things can break by 130,000 miles.
Old Nov 5, 2001 | 08:14 PM
Import RP's Avatar
Default Re: Opinions Needed!! (laughin2.2)
Yeah, don't get an automatic, and make sure its an SI, NOT an s...unless you plan on doing an engine swap.
Old Nov 5, 2001 | 08:25 PM
Mike95lude's Avatar
SI will have a dual tipped exhaust
S has a single tip
By the way, the S model SUCKS....only should a woman own one
Old Nov 6, 2001 | 04:06 AM
LudeBehavior's Avatar
New User
Default Re: Opinions Needed!! (Mike95lude)
Don't buy a prelude unless it has a stamp on the engine block, right by the header on the left side "h22a1" or "h22a" Ack and never get an automatic, eighs more, more to fix and slower.
Old Nov 6, 2001 | 04:23 PM
mattmw88's Avatar
I totally agree. I have a 92 s w/ 123,000 and it's a five speed. I couldn't wait to save up enough to get a vtec, so now I'm going to swap w/ the h22a. I have had no problems at all so far, just that now and then some very quiet, yet distinct to me, not very sever "issues" w/ my tranny. You won't regret anything about this purchase except that it's not a vtec and it's auto "eewwww!!!"
Old Nov 7, 2001 | 01:20 AM
buh_buh's Avatar
The way you can tell an S from an Si is that the S has no sunroof and the Si has the sunroof. And an H23 isn't necesserily a bad engine. Just because its not a H22 doesn't mean it not as good. If your looking to turbo the engine, H23 is probably better because the turbo doesn't interfere with the vtec. and I BELIEVE the H23 has more torque than the H22. Someone will need to confirm me on that one.
[Modified by buh_buh, 10:22 AM 11/7/2001]
Old Nov 7, 2001 | 10:32 AM
976's Avatar
976
New User
Default Re: Opinions Needed!! (buh_buh)
Try to go 93 w/ vtec - H22A engine.
Old Nov 7, 2001 | 10:45 AM
JG Luder's Avatar
S has a single tip
*BUZZZZZZZZZZZz* Wrong. The S still has the dual tips on the muffler. My woman owns one... er.. DID own one I guess. She wrecked it this weekend and we'll see if it's savable.
If you have power door locks then I'm 99% sure you have an Si. Look under the hood though, and to the left of the exhaust manifold you will see a place that should say H23A. Thats an Si... if it says F22 then you are getting an S model.
Old Nov 7, 2001 | 02:42 PM
Greyout's Avatar
" SI will have a dual tipped exhaust
S has a single tip"
not true
an S will have hubcaps, no power locks (usually), and not say DOHC on the valve cover.
[Modified by JDM LUDE, 11:42 PM 11/7/2001]
Old Nov 7, 2001 | 02:47 PM
JG Luder's Avatar
Default Re: Opinions Needed!! (JDM LUDE)
S has a single tip"
not true
And we have a winner. The only reason I didn't mention the hubcaps is that it's very easy to slap a set of Si or VTEC rims on there. Much easier than power locks.
Also, if I'm not mistaken, the Si doesn't actually SAY "DOHC" on the motor. I'll go double check myself.
rmichels
Dec 17, 2007 05:41 PM
Juvenile
Mar 21, 2005 06:44 AM
arjunsan
Jun 21, 2004 05:55 PM
typer_801
Aug 7, 2001 11:13 AM
