A/C Problem, warm at idle, cold on the go
Old May 9, 2004 | 11:33 AM
PolySquared's Avatar
Default A/C Problem, warm at idle, cold on the go
With the A/C turned on, and if i'm at idle for a long period of time, I could slowly feel the a/c warming up a bit.. As soon I get on the go, the a/c begins to get cold again.
This problem started ever since I replaced the a/c fan with a 10' pusher fan due to my turbo setup.
Could it be my fan isn't cooling enough?
Old May 9, 2004 | 02:10 PM
Chiovnidca's Avatar
Default Re: A/C Problem, warm at idle, cold on the go (PolySquared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PolySquared &raquo;</TD></TR><TR><TD CLASS="quote">
Could it be my fan isn't cooling enough?</TD></TR></TABLE>
That's a good possibility, the condensor needs good airflow to do it's job. Does the fan fit up against it? Would making a shroud push more air through?
Old May 9, 2004 | 10:43 PM
Default Re: A/C Problem, warm at idle, cold on the go (Chiovnidca)
it does fit against the radiator and i wouldn't think a shroud would help more air flow.
Old May 10, 2004 | 03:15 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PolySquared &raquo;</TD></TR><TR><TD CLASS="quote">it does fit against the radiator</TD></TR></TABLE>
Do you mean the condensor? What year and model car?
Old May 10, 2004 | 06:05 AM
x00gsr's Avatar
recharge your a/c
Old May 10, 2004 | 07:24 AM
-Justin-'s Avatar
Default Re: A/C Problem, warm at idle, cold on the go (x00gsr)
yeah, u most likely need more refrigerant. sounds like a problem i had in the past. Recharged the system and was fine, also look for any leaks in the system.
1baddturbosi
Jun 28, 2008 08:31 PM
DCshoecompany
Sep 10, 2007 11:23 AM
Babakarab
Jun 15, 2006 09:27 AM
NA JDM GSR
May 2, 2006 03:13 PM
pub
Jun 9, 2003 04:23 PM
