Can you Fool a CFS with a resister?
Old May 9, 2004 | 09:43 AM
mrtrex's Avatar
Default Can you Fool a CFS with a resister?
You would think that the magnet on the end creates some sort of voltage. Is it possable to fool it? I have a obd2 jdm motor that did not come with one. I have a usdm oil pump and sensor but tricking it would be a lot eaiser than installing it. Doea anyone know what the voltage is for that sensor? I am running a ex harness with a jdm b16b swap. Thanks
Old May 9, 2004 | 10:22 AM
irev210's Avatar
Default Re: Can you Fool a CFS with a resister? (mrtrex)
just use a JDM ecu or obd1 USDM chipped p28 w/ a conversion harness
Old May 9, 2004 | 10:29 AM
mrtrex's Avatar
Default Re: Can you Fool a CFS with a resister? (irev210)
I have a jdm ecu but when I go for emmissions it does not read all of the us sensors. I dont even know if it will read any sensors. I was going to use a usdm b16a ecu for the emissions test only. I have every sensor wired up to do so but this one.
Old May 9, 2004 | 10:41 AM
irev210's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrtrex &raquo;</TD></TR><TR><TD CLASS="quote">I have a jdm ecu but when I go for emmissions it does not read all of the us sensors. I dont even know if it will read any sensors. I was going to use a usdm b16a ecu for the emissions test only. I have every sensor wired up to do so but this one.</TD></TR></TABLE>
you dont need the CFS to pass emissions.... a CFS wont make your car burn cleaner.
Old May 9, 2004 | 10:48 AM
mrtrex's Avatar
Yes I know but when you use a usdm ecu it throws a check engine light. You cant pass the test here unless the check engine light is off. They plug in a obd2 scanner to see if there are any codes. This is why I am looking to fool it.
Old May 9, 2004 | 03:45 PM
boostn420's Avatar
its not a specific voltage its a series of pulses that will differ with engine speed. Good luck with fooling it i'd just install it.
Old May 9, 2004 | 04:41 PM
irev210's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrtrex &raquo;</TD></TR><TR><TD CLASS="quote">Yes I know but when you use a usdm ecu it throws a check engine light. You cant pass the test here unless the check engine light is off. They plug in a obd2 scanner to see if there are any codes. This is why I am looking to fool it.</TD></TR></TABLE>
so whats wrong with just running a obd2 JDM ecu?
Old May 9, 2004 | 04:58 PM
mrtrex's Avatar
I dont know if it will be able to pass obd2. I am not sure if they will be looking for the sensors that the JDM ecu does not have.
znoj
Engine Management and Tuning
Feb 21, 2011 11:00 AM
vinuneuro
May 25, 2009 12:54 PM
HaNsElBaDaSs
Sep 25, 2006 04:30 PM
shyxboy
10
Apr 20, 2006 04:39 PM
hb_racer
13
May 13, 2004 08:54 AM
