burning oil!!
Old May 9, 2004 | 06:01 AM
B18PoweredCivic's Avatar
Default burning oil!!
I burn about a quart if oil every 1000-1500 miles...Car runs strong...doesnt smoke..no leaks...What do you think it could be?...Compression and leak down test on the way...Its a 00 b16 in a eg...also I added some RESTORER oil additive....guess well see what happens
also when i check the oil it seems to be low on the dip stick....but when i put the dip stick in and turn it...it comes out showing that my oil level is fine....any thoughts
Old May 9, 2004 | 06:42 AM
Rod.'s Avatar
Default Re: burning oil!! (B18PoweredCivic)
i would just do the leak down test.
Old May 9, 2004 | 05:58 PM
xerox445's Avatar
Default Re: burning oil!! (redturbocivic)
hey you ****...i guess i'll help you cause im a nice guy...
your rings are probly shot, compression is going past the rings, into the crankcase, causing positive crankcase pressure. Its pushing the oil into the head and out anywhere it can go. Its going out the PCV valve on the valve cover, into your intake mani and burning it. Do a leakdown test to comfirm this.
also could be headgasket related, check your coolant, do you have little beads of oil in it?
Old May 10, 2004 | 10:04 AM
hahahaha....look who it is...anyways...probably a ring but I put a new motor in already so **** it....
jonyi27
Jul 8, 2013 03:25 AM
serjey15
Dec 4, 2010 07:20 PM
oilguzzler
Mar 7, 2007 08:39 PM
Jeff
Apr 18, 2005 06:23 AM
Accel Junky
Apr 28, 2003 02:18 PM
