D15B7 Track Time, Should it be better suggestions
Old May 9, 2004 | 04:34 AM
n_23_s's Avatar
Default D15B7 Track Time, Should it be better suggestions
I have a 95 Civic Dx 4DR Sedan. Here is my setup
D15B7 (new motor I have put 26,000 on it. its all it has on it)
Injen Cold Air Intake (3.5" Pipe)
AEM Bypass Valve
62MM BBK GSR Throttle Body
DC Sports 4-2-1 Header w/wrap on it
No Cat
3 Degrees Advance Ignition Timming
NGK Iridium Plugs
Stock tires 175/70/13 with 35psi in it.
Installed a Strut Tower Bar After the run should help with traction a bit.
Ex Gauge Cluster. I almost forgot to mention about my stereo adds about 250lbs+
My problem is if I start slow the my 1/4' mile time sucks, but if I dump the clutch at 6800 rpm's this is when I ran the best 1/4' mile.
my time is 16.9 @Darlington, SC.
I am installing a fuel pressure gauge and fuel pressure regulator soon.
I will install Quafe LSD and SRR 4.9 soon also. How much will this help?
Modified by n_23_s at 3:20 PM 5/13/2004
Old May 9, 2004 | 04:45 AM
n_23_s's Avatar
Default Re: D15B7 Track Time, Should it be better suggestions (n_23_s)
Here is my time slip, rt sucks I know
R/T .927
60' 2.594
330 7.116
1/8 10.902
MPH 64.39
1000 14.2
1/4 16.9
MPH 81.09
Old May 9, 2004 | 06:19 AM
spooncivic1's Avatar
i have a 92 dx hatch, i ran a 15.81 at rockingham NC.
no back interior,
open header,
and some bald *** vx wheels, 175/70/13
i was launching at about 3500 and had a 2.2 60'
and my engine has 175k on it also
Old May 9, 2004 | 06:22 AM
Skip01's Avatar
Default Re: D15B7 Track Time, Should it be better suggestions (spooncivic1)
Try and launch around 3500-4000,and no more clutch dumps from 6800.Feather it out too get a better start.You can also try and lower yout tire pressure a bit.Just keep practicing.
Modified by Skip01 at 5:21 PM 5/9/2004
Old May 9, 2004 | 06:25 AM
infinatenexus's Avatar
You need a cam
Old May 9, 2004 | 08:53 AM
BauleyCivic's Avatar
Risky Business
Default Re: (infinatenexus)
I ran the exact same time with a D15B7 sedan with intake and exhaust. First of all your 60ft sucks ***. Lower your tires to 20psi...and then let the clutch out easy when you start. When your 60fts are in the 2.2's...thats when you know you're reaching the full potential of your car.
As far as modifications go, if you aren't going swap or turbo there are two very important things that you need.
1) D16Z6 or D16Y8 transmission. The MUCH shorter gear ratios will give a boost in acceleration.
2) A good cam. http://www.exospeed.com has a great lineup of street and race cams that will give you a good amount of power from your d15B7. You should also get a cam gear, fuel pressure regulator and gauge when you get a cam. An ECU upgrade is optional.
Old May 9, 2004 | 09:03 AM
Jimmy's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n_23_s &raquo;</TD></TR><TR><TD CLASS="quote">Here is my time slip, rt sucks I know
R/T .927
60' 2.594
330 7.116
1/8 10.902
MPH 64.39
1000 14.2
1/4 16.9
MPH 81.09</TD></TR></TABLE>
Hey!
You all post your slips in the thread..
https://honda-tech.com/zerothread?id=858511
Old May 9, 2004 | 09:20 AM
BANting's Avatar
Default Re: D15B7 Track Time, Should it be better suggestions (Jimmy)
at LACR
car: del sol
motor:d15b7 w/180,000 miles
mods: shortram intake
ran 16.8's with 2.4 60's but i know i can hit lower first time at the track
Old May 9, 2004 | 10:27 AM
Eee Pee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n_23_s &raquo;</TD></TR><TR><TD CLASS="quote">I will install Quafe LSD and SRR 4.9 soon also. How much will this help?</TD></TR></TABLE>
The LSD won't change anything, but the change in FD sure will. Especially if it's in a EX/Si tranny.
Old May 9, 2004 | 11:58 AM
n_23_s's Avatar
Default Re: D15B7 Track Time, Should it be better suggestions (Eee Pee)
The Ex/Si and the Dx trans are almost the same. The only diffrence is the fd (which I am going to change anyway). Some of them had a .750 fifth gear mine has a .700. That is why I am going to use the dx tranny.
thrty8street's Avatar
do some weight reduction, take out your back seats and your spare and jack
Old May 9, 2004 | 12:19 PM
Eee Pee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n_23_s &raquo;</TD></TR><TR><TD CLASS="quote">The Ex/Si and the Dx trans are almost the same. The only diffrence is the fd (which I am going to change anyway). Some of them had a .750 fifth gear mine has a .700. That is why I am going to use the dx tranny.</TD></TR></TABLE>
They are not the same at all.
Available Stock Ratios
EX/Si
1st-----3.250
2nd-----1.900
3rd-----1.250
4th-----0.909
5th-----0.750 for Si HB and Del sol Si
or------0.702 for 2 dr or 4 dr sedan
Final Drive---4.250
DX/LX
1st-----3.250
2nd-----1.762
3rd-----1.172
4th-----0.909
5th-----0.702
Final Drive---4.058
Credit goes to Mista Bone for the numbers.
Here's his page. http://home.cinci.rr.com/mistab0ne/tranny.html
Old May 9, 2004 | 12:52 PM
Risky Business
No they are not, I've had both transmissions and the EX's 1st to 2nd and 2nd to 3rd shifts are so much shorter than the DX. Do yourself a favor and get the EX transmission first. I personally am not a fan of the 4.7 or 4.9 FD's because of the high cruising RPM's on the highway.
Old May 9, 2004 | 01:04 PM
n_23_s's Avatar
Default Re: D15B7 Track Time, Should it be better suggestions (BauleyCivic)
My bad. 1st gear and 4th are the only same. Any how All my gears will be shorter b/c the final drive will be a lot better.
EVIL Hx Coupe
Apr 17, 2005 03:45 PM
slowsleeper
Apr 11, 2004 11:54 PM
Jimmy
13
Apr 10, 2004 02:18 PM
RPRacing
Mar 15, 2004 06:06 PM
ZeroTheHero
Sep 3, 2002 01:56 PM
