Bad Wobble, Cant figure it out. Need some Ideas.
I threw a first gen b16 into an 88 Crx Si, after the swap I have a really mean wobble that starts at around 90, but then continues all the way back down to 30mph. Go to park it and go drive around and its fine until you hit high speeds again and the wobble will stay all the way down the low speeds. Its coming from the front of the car, shakes the whole front really bad at the high speeds. The car didnt have this problem before it met the B, drove fine.
Hasport mounts
replaced Axels, correct half shaft
New Ball joints
Tires Balanced
Alignment
Swapped out front rims and tires also
Tein S tech for susp, stock shocks
Im running out of Ideas, Ive been under the car checking for anything lose and I dont see anything wrong. Im not a fan of paying a shop to work on my car, so im really trying to avoid that option. Also having someone else turning a wrench on my ride. Any Ideas would be very helpful
Hasport mounts
New Ball joints
Tires Balanced
Alignment
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller »</TD></TR><TR><TD CLASS="quote">are the axles seated right?</TD></TR></TABLE>
yup, Ive had them in/out some many times now.
DC 2
May 10, 2004 06:40 PM
DC 2
May 10, 2004 06:31 AM
