CTR rings on CP pistons?
Old May 8, 2004 | 07:15 PM
DexterThEG's Avatar
Default CTR rings on CP pistons?
I'm looking at a set of used CPs for my build from FastAssEG in the classifieds.. I have a set of new CTR std. bore rings. does anyone know if there is even a chance of them working with those pistons??
Old May 9, 2004 | 05:44 PM
DexterThEG's Avatar
anyone???
Old May 9, 2004 | 07:34 PM
Supernatural's Avatar
Default Re: (DexterThEG)
i wouldnt do it.....
buy the rings that were designed to work with those pistions
Old May 9, 2004 | 08:48 PM
Dan GSR's Avatar
Default Re: (SUPERNATURAL)
most likely will not work, just call cp and get new rings, they are probably like $100 for a set
Old May 10, 2004 | 02:46 PM
DexterThEG's Avatar
thanks guys
Old May 13, 2004 | 08:57 AM
DexterThEG's Avatar
I checked with CP and they said the rings would work fine. w00t! so there's a lesson I suppose
Old May 13, 2004 | 10:25 AM
99B16Si's Avatar
id trust CP's input but for some reason i doubt the height and depth of a CP ring is the same as a oem honda. also make sure u file the rings correctly
Old May 13, 2004 | 01:40 PM
Dan GSR's Avatar
Default Re: (99B16Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99B16Si &raquo;</TD></TR><TR><TD CLASS="quote"> i doubt the height and depth of a CP ring is the same as a oem honda. also make sure u file the rings correctly</TD></TR></TABLE>
my thoughts exactly
Old May 13, 2004 | 06:35 PM
DexterThEG's Avatar
yea.. I measured both comp. rings and sent them the specs. As soon as I get the pistons, I'll check the gaps.. oh and about the filing, I've seen that being done, and know we have the tool at work, but what's the procedure??
Old May 13, 2004 | 06:40 PM
99B16Si's Avatar
i would just use CP rings man. dont chance it. use the rings specified for the piston. there is no advantage to using oem rings
na_lseg
Oct 17, 2005 03:38 PM
HondaGuy02
May 22, 2005 01:47 PM
MugenB16A2
19
Nov 28, 2003 09:18 AM
hybridEj6
Apr 15, 2003 07:50 PM
vtec69
Nov 21, 2001 06:47 AM
