Tapping brake booster for vacuum mani
Did a search and nothing came up. Just need to know what size tee i need to tap brake booster line.
edit: I got a 3/4 in but it's the same size as the booster line. Is the brake booster line pretty thick or can it be squeezed on.
Modified by djfob at 10:09 PM 5/8/2004
It's no a Ge but is similar....haven't tried the 3/4 yet,just trying to get everything together before the install to make things a bit smoother. The 3/4" tee seems to have the same outer diameter of the brake booster line and might work pending on how thick the line is. I have never seen the line cut so I have no idea how thick it is. Just seeing what others have used.
