mt main ecu fuse under the hood keeps blowing, how do i fix this?!!?!!
Old Nov 5, 2001 | 03:51 AM
chuckd05's Avatar
New User
Default mt main ecu fuse under the hood keeps blowing, how do i fix this?!!?!!
I will be just driving and my car will turn off and my main ecu fuse will be blown and i have to change it to get the car started again. what could be causing it to do this, any ideas? its by far yet the biggest pain in the *** problem ive had cuause it drives for like 3-5 minutes than happens?
Old Nov 5, 2001 | 06:40 AM
Blown90hatcH's Avatar
Default Re: mt main ecu fuse under the hood keeps blowing, how do i fix this?!!?!! (chuckd05)
If you put a larger fuse in it.....it will not blow, but it will melt some of the yellow wires comming from the main relay. You have a short somewhere that is ground out a power wire. I had the same problem and it turned out that the power wire on the O2 sensor had been rubbed up against the motor and caused a bare wire and it was grounded out on the motor. Time to trace some wires my friend.
Old Nov 5, 2001 | 07:33 AM
DR. ON POINT's Avatar
Banned
Default Re: mt main ecu fuse under the hood keeps blowing, how do i fix this?!!?!! (Blown90hatcH)
did u try and rewire anything
Trvsteggy
Apr 21, 2018 02:54 PM
jrp355
Oct 19, 2011 07:49 AM
Blue94Accord
Dec 26, 2010 04:06 PM
EGKREW
Dec 20, 2008 08:33 AM
TORQUE MONSTER
Apr 21, 2003 01:41 PM
