Can anyone help me identify the condition of my sprk plugs?
Old May 8, 2004 | 02:18 PM
Shorty C's Avatar
Default Can anyone help me identify the condition of my sprk plugs?
I know that black is too rich and white is too lean or vice verse, but most of the plugs have black and white on them. I thought the best mixture yields lightish brown results?
if the pics dont show, its probably imagestation, they're always on and off when i host pics from them.
cylinder 1:
cylinder 2:
cylinder 3:
cylinder 4:
I just need help because im wondering why im throwing codes 71-74(cylinder 1-4 misfires). I have NGK wires also and they seem to work fine because when the car is idling, i pulled each wire out 1 at a time and the car bogged on all four wires.
the car is a 99 si with bolt ons and fpr set at 40psi
Old May 8, 2004 | 02:50 PM
teglsturbo's Avatar
Default Re: Can anyone help me identify the condition of my sprk plugs? (Shorty C)
how many miles on plugs? cyl 1 and 3 look bad, try a new set of plugs. go about 2 hwat ranges colder than stock, ex:stock ngk # ****-11 go to ****-9 let me know how it works.
Old May 8, 2004 | 08:02 PM
Jim Truett's Avatar
How many miles on the engine? What kind of fuel injectors are you using, and how long has it been since they were properly cleaned?
Old May 8, 2004 | 11:35 PM
Shorty C's Avatar
Default Re: Can anyone help me identify the condition of my sprk plugs? (Jim Truett)
98,xxx miles
stock injectors
never cleaned
Old May 9, 2004 | 08:59 AM
boostn420's Avatar
Those plugs all look great from here. I would check the resistance of the plug wires, and maybe the coil. Hows the gap on the plugs, if its excessive it may be too much resistance under load. There isnt much of an engine load at idle, so it might be difficult to tell just by pulling plugs wire with it running. Unless you could pull one while your doing 80 up a hill.
Dont worry about cleaning your injectors, there's additives in the fuel for that.
Old May 9, 2004 | 09:55 AM
Jim Truett's Avatar
Default Re: Can anyone help me identify the condition of my sprk plugs? (boostn420)
Just by looking at the pictures there is a lean condition on #3.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostn420 &raquo;</TD></TR><TR><TD CLASS="quote">Dont worry about cleaning your injectors, there's additives in the fuel for that. </TD></TR></TABLE>
Whether there are additives in the fuel or not, injectors still get clogged or develop flow problems. Educate yourself: http://www.rceng.com/service.htm#INJECTOR
ncskate1985
Nov 23, 2007 12:17 PM
95c1v1cs1
Apr 21, 2005 07:32 PM
jerseydevil
Dec 5, 2004 07:34 AM
bullz
Jul 15, 2002 10:19 PM
bullz
Jul 6, 2002 05:54 PM
