How do you REMOVE Bird Shit Stain?
Old May 8, 2004 | 09:52 AM
AL ASPIRATED's Avatar
Default How do you REMOVE Bird **** Stain?
man a ******* bird decided to take a diarehea **** all over my car. i cleaned all of it off, but one spot has the **** out line on there. The paint is only 2 months old, so im hella pissed.
i dont noe much about cleaning, so what can i use to remove it?
THANKS for all your help
Old May 8, 2004 | 09:59 AM
xx dc2teg xx's Avatar
Default Re: How do you REMOVE Bird **** Stain? (AL ASPIRATED)
theres still an outline after you washed it? try a claybar
Old May 8, 2004 | 10:11 AM
EM2MoNsTeR's Avatar
Default Re: How do you REMOVE Bird **** Stain? (xx dc2teg xx)
You are going to need a paint cleaner. A clay bar would probably make it worse. Be careful don't use too much pressure.
Old May 8, 2004 | 10:42 AM
krew's Avatar
meguiars cleaner wax
Old May 8, 2004 | 11:00 AM
Code Blue's Avatar
Default Re: (Active760)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Active760 &raquo;</TD></TR><TR><TD CLASS="quote">meguiars cleaner wax </TD></TR></TABLE>
definitely, or some meguiar swirl free polish, 3 cut
Old May 8, 2004 | 11:18 AM
B18bEK's Avatar
try licking it.
Old May 8, 2004 | 11:20 AM
tilt.'s Avatar
Default Re: (B18bEK)
usually bird stains like that are wetsanded, then polished. use a 1500+ grit sandpaper, alot of water, and very little pressure. then polish it. easy as pie.
Old May 8, 2004 | 11:48 AM
JforJonathan's Avatar
damn i hate birds. i got the same type of **** stain outline on my trunk
Old May 8, 2004 | 11:54 AM
jeremy.'s Avatar
Default Re: How do you REMOVE Bird **** Stain? (Dj Villain)
try picking at it with your nail
Old May 8, 2004 | 12:07 PM
x916's Avatar
Default Re: How do you REMOVE Bird **** Stain? (ekay_jeremy)
i use toilet paper
Old May 8, 2004 | 12:24 PM
92nb's Avatar
Default Re: How do you REMOVE Bird **** Stain? (VoLTRoNx916)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VoLTRoNx916 &raquo;</TD></TR><TR><TD CLASS="quote">i use toilet paper </TD></TR></TABLE>
I use TP too. I hope you guys do.....
I doesn't help if it's dry and crusty...
Old May 8, 2004 | 01:07 PM
Phil DeVtec's Avatar
oh my god that stuff is awesome!
Old May 8, 2004 | 01:41 PM
nightrider's Avatar
how long did you let the bird **** stay on there?
Old May 8, 2004 | 03:45 PM
95sihb's Avatar
https://honda-tech.com/zerothread?id=790409 Please dont wetsand it, if you never done it you will f-up your new paint job, instead go to your autostore of choice and buy a bar of claybar kit , basically all you do is wet the area you want to work on, use really soappy water put it on the area and on the clay and rub back and forth with lite pressure ....stop after like 3-4 strokes then put some water and see if you need to rub more clay ,before you rub the stain again kneed the clay fold the clay into it's self and rub again 3-4 stokes, the stain will disappear, if i was you i would let the area dry real good then but some wax on the area and you will be good to go .
P.s if you drop the bar of clay on the ground /and or drop it inside the bucket you use to hold water .the clay will pick up small particles of dirt and you will scratch your paint ... so throw it away dont try to pick all the dirt of the clay because you will not be able to get it all sorry for my bad spelling
Old May 8, 2004 | 07:30 PM
Default Re: How do you REMOVE Bird **** Stain? (nightrider)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nightrider &raquo;</TD></TR><TR><TD CLASS="quote">how long did you let the bird **** stay on there?</TD></TR></TABLE>
it sat somewhere between, 1-8 hrs while i was at work.
i was told that rubbing compiund would take it off, or get it buffed????
Old May 8, 2004 | 08:19 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: How do you REMOVE Bird **** Stain? (95sihb)
I don't think a clay bar will work. They are designed to remove contaminants that sit on top of the surface of the paint. Sounds to me like his problem is that the acids in the bird crap actually etched itself into the paint. That means the outline on his paint is not anything on it, but it's actually an imperfection in the paint itself. Buffing might take care of it, if the etching is only in the clearcoat. If it's down to the actual paint, it will have to be repainted and/or re-cleared.
Old May 8, 2004 | 09:32 PM
Weapon's Avatar
OT: do u look at it after u wipe ur butt?
Old May 8, 2004 | 09:34 PM
WhoisDan's Avatar
3M rubbing compound.
Old May 8, 2004 | 09:36 PM
MTK Kommander's Avatar
Default Re: How do you REMOVE Bird **** Stain? (Weapon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Weapon &raquo;</TD></TR><TR><TD CLASS="quote">
OT: do u look at it after u wipe ur butt? </TD></TR></TABLE>
when u wipe, do you look at the tissue?
most folks do, it aint even an issue.
Old May 8, 2004 | 10:15 PM
Weapon's Avatar
Default Re: How do you REMOVE Bird **** Stain? (MTK Kommander)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MTK Kommander &raquo;</TD></TR><TR><TD CLASS="quote">
most folks do, it aint even an issue.</TD></TR></TABLE>
I always do, cos if u dont how do u know if ur butt is clean or not
Old May 9, 2004 | 03:05 PM
LSeeper's Avatar
toothpatse
Old May 9, 2004 | 03:13 PM
Default Re: (whoisdan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whoisdan &raquo;</TD></TR><TR><TD CLASS="quote">3M rubbing compound.</TD></TR></TABLE>
i heard good things about this stuff. is it really that good? i want to try.
Old May 9, 2004 | 03:16 PM
brad.'s Avatar
I was told to use a 50/50 water vinegar solution, just apply it to the affected area with a terry or microfiber towel
Old May 9, 2004 | 05:20 PM
92nb's Avatar
Default Re: (Phil DeVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phil DeVtec &raquo;</TD></TR><TR><TD CLASS="quote">
i heard good things about this stuff. is it really that good? i want to try.</TD></TR></TABLE>
3M Compound Supplies are the best in the business. If you know what you are doing, spend the money for 3M.
Pro's use it.
Old May 10, 2004 | 10:45 PM
WhoisDan's Avatar
Because professional painters use it.
