car alarm install help 93 hatch
Im installing my own car alarm in my 93 hatch... and so far its going well, but i have two wire location questions...\
1. I have a factory interconnect harness with one big plug for the +12v, ignition input (has the relay for starter interupt in it), this also has another plug that the one thats already in the car plugs back into. and there is also one little plug that just has the ignition input wire
just by looking around under the dash i found a place were the big one fits on the back of the fuse box, and a bunch of ones were the little ones fit (pictured), ive gathered that the top of these 5 is the run/acc and is were i beleive the plug goes... does anyone know if these are the correct places to wire into? thanks for any help.
yeah, my problem is that its not really clear what ignition really means... wether its input, or output, or "run" or what... i was hopeing someone knew, but i guess not.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StrangerWitCandy »</TD></TR><TR><TD CLASS="quote">bump... help out a new installer who needs some help
:Calvery Charge:
You are in luck...but you need a meter or test light to find
out which position is which. Battery,Ignition,Start (?),Access and
park lights circuits are all in those male plugs..the fuse panel should
list them.
Gotta love a Honda
</TD></TR></TABLE>:Calvery Charge:
list them.
Gotta love a Honda
If you're looking for an ignition wire, you put your test light up to the terminal, and start your car. If the light stays on continually through the cranking of the motor, and only dims slightly, then you've got an ignition wire. If the light goes out when you crank the car, then it's accessory wire. If the light only comes on when you crank the car, then that's your starter wire. If the light is on all the time, even when your key is out, then that's your constant 12v wire.
Hope that helped!
Hope that helped!
eh9deux
Sep 24, 2010 08:38 AM
GsDAteg
Audio / Security / Video
Mar 18, 2010 04:40 AM
