ITR valve springs and skunk2 stage 1 cams
I got a couple questions guys so bare with me.
First off what can i do to distinguish the differance between the Exhaust and intake valve springs? There are NO markings on them, they are used.
And secondly when I go to install the cams and valve springs what all will i need to install the valve springs, I got a pretty idea about the cams., but i have never seen anyone install valve springs. Are they pretty easy to get to??
And one last question. I already ran a search for this and it confused me more, on the skunk2 stage 1's is there and M and a 2 on the cam?
Thanks alot!
Thanks alot!
I would take off the head if I were you. If you drop a valve in the cylinder, you'll be upset. Go to your local autoparts store and get a Chilton manuel or a Helms manual. These will be worth its weight in platnium. This will tell you everything you need to know. As for the vavle springs, take them to a dealer and talk to one of the parts guys, they'll be able to tell you whats what.
prodragEG
Sep 26, 2007 02:51 PM
