Jegs E-Cutout??
Old May 7, 2004 | 10:29 PM
GSR-Civic's Avatar
Default Jegs E-Cutout??
Hey guys, does anybody know where to buy one of these bad boys?
I'v search.
Old May 7, 2004 | 10:39 PM
GSR-Civic's Avatar
nevermind, I found it
http://www.jegs.com/cgi-bin/nc...r=361
Old May 7, 2004 | 10:55 PM
Jawad.'s Avatar
Default Re: (GSR-Civic)
You'd be better of with an electric powered one.. instead of the cable release type
Old May 7, 2004 | 11:42 PM
Built Beast's Avatar
Default Re: (John Kerry)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by John Kerry &raquo;</TD></TR><TR><TD CLASS="quote">You'd be better of with an electric powered one.. instead of the cable release type</TD></TR></TABLE>
I agree
Old May 8, 2004 | 02:50 PM
GSR-Civic's Avatar
well I was thinking the same but I wanted to weld up a small pipe to the cutout and put a small little muffler tip on it, so it will sound somewhat nice.. instead of open header... you know what I mean? and it dont look like the electric supports that
Old May 8, 2004 | 02:56 PM
STN_Pat's Avatar
why would the electronic one be better ?
Old May 8, 2004 | 02:58 PM
Casey's Avatar
Default Re: (STN_Pat)
that cut out is for a 2" od pipe. thats tiny
Old May 8, 2004 | 02:59 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Default Re: (Casey)
they come in various sizes, you know.
Old May 8, 2004 | 03:00 PM
miahmouse's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STN_Pat &raquo;</TD></TR><TR><TD CLASS="quote">why would the electronic one be better ?</TD></TR></TABLE>
it wouldn't be, they're easier to install but take longer to open/close...
Old May 8, 2004 | 03:01 PM
Casey's Avatar
Default Re: (SkyeC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkyeC &raquo;</TD></TR><TR><TD CLASS="quote">they come in various sizes, you know.</TD></TR></TABLE>
the one he linked is 2" just thought id let him know before he orders a cut out small enough for oem piping. is that ok
Old May 8, 2004 | 03:13 PM
GSR-Civic's Avatar
WHat do you guys think about this?
I was wondering if a Electric would let me do this..
I really dont like the sound of open header, with a small muffler tip it still would be loud... but it will muffle the noise a BIT
Old May 8, 2004 | 03:15 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Default Re: (Casey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Casey &raquo;</TD></TR><TR><TD CLASS="quote">the one he linked is 2" just thought id let him know before he orders a cut out small enough for oem piping. is that ok</TD></TR></TABLE>
no.
Old May 8, 2004 | 03:20 PM
EG2 SiR's Avatar
would a tip really make a difference?
Old May 8, 2004 | 03:21 PM
Unjockable's Avatar
New User
on these, when you uncap it, the air will still flow to the other direction and into the exhaust, right?
Old May 8, 2004 | 03:39 PM
GSR-Civic's Avatar
Default Re: (EG2 SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG2 SiR &raquo;</TD></TR><TR><TD CLASS="quote">would a tip really make a difference?</TD></TR></TABLE>
A tip wont make a diff... but it will make the noise sound better IMO
Old May 8, 2004 | 03:47 PM
Casey's Avatar
Default Re: (SkyeC)
no.</TD></TR></TABLE>
ok i take it back
Old May 8, 2004 | 04:02 PM
Knightmare69's Avatar
Would it make it more effective to run 2 of these? One right in front of the other, so that when you open the cut-out section, you close off the one in front so that ALL the gasses exited through the open section. Does anyone get what I'm saying? Maybe I need to draw a diagram.
Old May 8, 2004 | 04:36 PM
racerx707's Avatar
Why the hell would you buy an exhaust cutout only to put a muffler on it???
Old May 8, 2004 | 04:56 PM
Unjockable's Avatar
New User
Default Re: (Knightmare69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Knightmare69 &raquo;</TD></TR><TR><TD CLASS="quote">Would it make it more effective to run 2 of these? One right in front of the other, so that when you open the cut-out section, you close off the one in front so that ALL the gasses exited through the open section. Does anyone get what I'm saying? Maybe I need to draw a diagram.</TD></TR></TABLE>
i know what you mean. that's why i'm asking if the air flows to the other end of if it stops. guess you answered my question.
wouldn't be that effective if the air keeps going out to the muffler and also exiting to the side.
Old May 8, 2004 | 05:58 PM
Soccerking3000's Avatar
Default Re: (Unjockable)
the exhaust air is going to find the fastest way out in general the cut-out part is a larger diameter and of course much shorter thus reducing the back pressure so 99% of the exhaust will go out the cut-out and not through your primary exhaust
Old May 8, 2004 | 07:09 PM
Skip01's Avatar
Default Re: (Soccerking3000)
I've heard conflicting stories about each different type of cut-out.
The cable one gets knotted and the electric one doesn't shut all the way.They are sweet though.Good Luck.
Old May 8, 2004 | 07:39 PM
Unjockable's Avatar
New User
wow....is this true? can anyone confirm?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">the exhaust air is going to find the fastest way out in general the cut-out part is a larger diameter and of course much shorter thus reducing the back pressure so 99% of the exhaust will go out the cut-out and not through your primary exhaust</TD></TR></TABLE>
Old May 9, 2004 | 07:43 AM
SearchBeforeUPost!'s Avatar
yes its mere physics.
Old May 9, 2004 | 08:08 AM
Dengar's Avatar
Default Re: (SearchBeforeUPost!)
Why are you even thinking about putting a muffler on your e cutout. You aren't going to be running around with it open all the time, so who cares if it is loud for a short period of time.. If you are that concered with the volume level, just stick with you exhaust.
Old May 9, 2004 | 08:47 AM
egsleepercivic's Avatar
Default Re: Jegs E-Cutout?? (GSR-Civic)
put it after the cat or you will through*a code*when you open it up
Modified by egsleepercivic at 7:29 PM 5/9/2004
